CME Time is Caracas Venezuela
I have a customer with a CME is Caracas Venezuela.  The time zone there is 30 minutes ahead of the US, which is Zone 12 in Telephony-Service.  Please let me know how to offset the time displayed on the phone by 30 minutes.
Everyone's tags (2)
Hall of Fame Super Red
Hi Scott,
Couldn't you use;
Router(config)# telephony-service
Router(config-telephony)# time-zone 54
Syntax Description
number
Numeric code for a named time zone. The following are the selections. The numbers in parentheses indicate the offset from Coordinated Universal Time (UTC) in minutes.
Note The time shows incorrectly for phones configured in West Africa during the Summer Time. For West Africa, Summer Time or Daylight Savings Time (DST) is not used. There is no correct time zone in this time zone list to account for this time zone.
1—Dateline Standard Time (-720)
2—Samoa Standard Time (-660)
3—Hawaiian Standard Time (-600)
4—Alaskan Standard/Daylight Time (-540)
5—Pacific Standard/Daylight Time (-480)
6—Mountain Standard/Daylight Time (-420)
7—United States (US) Mountain Standard Time (-420)
8—Central Standard/Daylight Time (-360)
9—Mexico Standard/Daylight Time (-360)
10—Canada Central Standard Time (-360)
11—SA Pacific Standard Time (-300)
12—Eastern Standard/Daylight Time (-300)
13—US Eastern Standard Time (-300)
14—Atlantic Standard/Daylight Time (-240)
15—South America (SA) Western Standard Time (-240)
16—Newfoundland Standard/Daylight Time (-210)
17—SA Standard/Daylight Time (-180)
18—SA Eastern Standard Time (-180)
19—Mid-Atlantic Standard/Daylight Time (-120)
20—Azores Standard/Daylight Time (-60)
21—UTC Standard/Daylight Time (+0)
22—Greenwich Standard Time (+0)
23—Western Europe Standard/Daylight Time (+60)
24—GTB (Athens, Istanbul, Minsk) Standard/Daylight Time (+60)
25—Egypt Standard/Daylight Time (+60)
26—Eastern Europe Standard/Daylight Time (+60)
Syntax Description
number continued
27—Romance Standard/Daylight Time (+120)
28—Central Europe Standard/Daylight Time (+120)
29—South Africa Standard Time (+120)
30—Jerusalem Standard/Daylight Time (+120)
31—Saudi Arabia Standard Time (+180)
32—Russian Standard/Daylight Time (+180)
33—Iran Standard/Daylight Time (+210)
34—Caucasus Standard/Daylight Time (+240)
35—Arabian Standard Time (+240)
36—Afghanistan Standard Time (+270)
37—West Asia Standard Time (+300)
38—Ekaterinburg Standard Time (+300)
39—India Standard Time (+330)
40—Central Asia Standard Time (+360)
41—Southeast Asia Standard Time (+420)
42—China Standard/Daylight Time (+480)
43—Taipei Standard Time (+480)
44—Tokyo Standard Time (+540)
45—Central Australia Standard/Daylight Time (+570)
46—Australia Central Standard Time (+570)
47—East Australia Standard Time (+600)
48—Australia Eastern Standard/Daylight Time (+600)
49—West Pacific Standard Time (+600)
50—Tasmania Standard/Daylight Time (+600)
51—Central Pacific Standard Time (+660)
52—Fiji Standard Time (+720)
53—New Zealand Standard/Daylight Time (+720)
54—Venezuela Standard Time (-270)
55—Pacific SA Daylight Time (-180)
56—Pacific SA Standard Time (-240)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_t1ht.html#wp1029124
Usage Guidelines
This command works with the vendorConfig section of the Sep*.conf.xml configuration file, which is read by the phone firmware when the Cisco IP Phone is booted up. Certain phones, such as the Cisco Unified IP Phone 7906 , 7911, 7931, 7941, 7942, 7945, 7961, 7962, 7965, 7970 , 7971, and 7975, obtain Coordinated Universal Time (UTC) from the clock of the Cisco router. To display the correct local time, the time display on these phones must be offset by using this command.
This command is not required for Cisco Unified IP Phone 7902G, 7905G, 7912G, 7920, 7921, 7935, 7936, 7940, 7960, or 7985G.
For changes to the time-zone settings take effect, the Sep*.conf.xml file must be updated by using the create cnf-files command and the Cisco IP phones must rebooted by using the reset command.
Cheers!
Rob
In this version of CME 7.1.  The list of time zones only goes to 53.  It does not recognize 54.
Hi scottsassin:
Did you solve this issue? I'm facing the same problem...
Faimy
667
