04-06-2010 08:50 AM - edited 03-15-2019 10:07 PM
I have a very interesting problem.
I have two subscribers whose phones refuse to synch up to the correct time. They're both 1 hour off. Everybody elses are correct. I've had the subscribers log off then I reset the phones via CME GUI. That didn't work. I then had them log off and detach from power. After logging in again, that too didn't work.
Anybody have any ideas? Perhaps the phones are dysfunctional/bad?
Thank you for any help.
Solved! Go to Solution.
04-06-2010 11:15 AM
Hey Ross,
Call me paranoid, but I would do this after normal business hours
Here is a very similar thread I worked on with Karl where the EM phones
did not need to re logged-in but, better safe than sorry;
https://supportforums.cisco.com/message/1111139#1111139
Cheers!
Rob
04-06-2010 08:55 AM
Hey Ross,
Are these two phones the same exact models as the rest? If not
can you tell us the mix of IP Phone models working/not-working
Cheers!
Rob
04-06-2010 08:57 AM
Hi Rob,
Yes, these phones are all standard 2 line 7941 series. Their phones work perfectly fine too. The darn time just won't change.
Thank you
04-06-2010 09:02 AM
Hi Ross,
This is not an uncommon issue that should be quite fixable
Troubleshooting Incorrect Time Stamp on IP Phones in Cisco Unified CME
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/troubleshooting/guide/ts_time.html#wp1053981
After changing the time-zone setting you could follow these steps.
Usage Guidelines
This command works with the vendorConfig section of the Sep*.conf.xml configuration file, which is read by the phone firmware when the Cisco IP Phone is booted up. Certain phones, such as the Cisco Unified IP Phone 7906 , 7911, 7931, 7941, 7942, 7945, 7961, 7962, 7965, 7970 , 7971, and 7975, obtain Coordinated Universal Time (UTC) from the clock of the Cisco router. To display the correct local time, the time display on these phones must be offset by using this command.
This command is not required for Cisco Unified IP Phone 7902G, 7905G, 7912G, 7920, 7921, 7935, 7936, 7940, 7960, or 7985G.
For changes to the time-zone settings take effect, the Sep*.conf.xml file must be updated by using the create cnf-files command and the Cisco IP phones must rebooted by using the reset command.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_t1ht.html#wp1023398
under the telephony-service -
no create cnf-files
create cnf-files
Then reboot the individual phones
Hope this helps!
Rob
04-06-2010 09:04 AM
I will try this and update. Thank you!
04-06-2010 10:47 AM
Hi Rob,
Trying to figure this one out.
As I read it appears the .xml file has to be updated and all the phones have to be reset. Is this correct? Would this be an after hours fix? As I don't want to make a mistake and boot everybody during production hours. All the phones are configured for extension mobility. 95% of these people require helpdesk to get them logged back into their phones.
Thank you
04-06-2010 11:15 AM
Hey Ross,
Cheers!
Rob
04-06-2010 11:26 AM
We did it anyway. I talked to an engineer and he said he did this during NBH before. Ran it, rebooted the two subscribers and we're good.
Thank you sir.
04-06-2010 12:02 PM
Hey Ross,
Nice work my friend I told you I was paranoid!
Cheers!
Rob
