CME TO CM LICENSE UPGRADE FOR UNITY
hi all,
i hv CUE 2.2.2 (AIM-router2611),which shows license for CME. i want to integrate CUE to CM 4.1, is it possible to upgrade CUE license from CME to CM? if yes then How?
Thanks in Advance,
Re: CME TO CM LICENSE UPGRADE FOR UNITY
You can change the license type, but it will require a reinstall. See the following link.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel2_3/install/upg_lic.html
Hope this helps. If so, please rate the post.
Brandon
Hi Brandon,
can i convert the existing CME license into CCM? or i hv to download CCM license? if yes, then how can i retain my existing license?
pls guide.
You will have to download the CCM license. You could also download the CME license if you want to keep a copy. No need to retain it from the current system.
Hope this helps.
Brandon
Thanks Brandon
206
