CME to CME call fails across PRI
I hope someone can help me with a lab setup between two CME routers. Below is the relevant configs. I'm getting only a busy tone when calling from either side.
TIA.
r8#sh telephony-service
CONFIG (Version=8.5)
Branch2#sh telephony-service
CONFIG (Version=7.1)
r8#
isdn switch-type primary-ni
voice-card 0
dsp services dspfarm
controller T1 0/0/0
clock source internal
pri-group timeslots 1-3,24
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn protocol-emulate network
isdn incoming-voice voice
no cdp enable
voice-port 0/0/0:23
dial-peer voice 804 pots
preference 1
destination-pattern 80..
port 0/0/0:23
forward-digits all
prefix 18048888
telephony-service
max-ephones 2
max-dn 2
ip source-address 177.4.11.1 port 2000
auto assign 1 to 2
dialplan-pattern 1 7577777... extension-length 4
max-conferences 8 gain -6
web admin system name administrator password cisco
web admin customer name johndoe password cisco
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Dec 22 2011 13:11:26
r8#sh isdn stat
Global ISDN Switchtype = primary-ni
ISDN Serial0/0/0:23 interface
        ******* Network side configuration *******
        dsl 0, interface ISDN Switchtype = primary-ni
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x80000007
    Number of L2 Discards = 0, L2 Session ID = 215
    Total Allocated ISDN CCBs = 0
voice-card 0
controller T1 0/2/0
cablelength long 0db
interface Serial0/2/0:23
no ip address
encapsulation hdlc
no cdp enable
dial-peer voice 757 pots
preference 1
destination-pattern 70..
port 0/2/0:23
forward-digits all
prefix 1757777
telephony-service
max-ephones 2
max-dn 2
ip source-address 177.3.11.1 port 2000
auto assign 1 to 2
load 7941 SCCP41.8-4-2.S
dialplan-pattern 1 8048888... extension-length 4
dn-webedit
time-webedit
create cnf-files version-stamp Jan 01 2002 00:00:00
Branch2#sh isdn stat
ISDN Serial0/2/0:23 interface
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
    Layer 3 Status:
    Number of L2 Discards = 0, L2 Session ID = 64
Branch2#
r8#
Dec 22 18:23:40.395: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Calling num 7577777001
Dec 22 18:23:40.395: ISDN Se0/0/0:23 Q931: Sending SETUP  callref = 0x0080 callID = 0x8001 switch = primary-ni interface = Network
Dec 22 18:23:40.395: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0080
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Progress Ind i = 0x8583 - Origination address is non-ISDN
        Calling Party Number i = 0x2180, '7577777001'
                Plan:ISDN, Type:National
        Called Party Number i = 0x80, '180488888002'
                Plan:Unknown, Type:Unknown
Dec 22 18:23:40.439: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8080
Dec 22 18:23:40.439: ISDN Se0/0/0:23 Q931: RX <- CONNECT pd = 8  callref = 0x8080
Dec 22 18:23:40.443: %ISDN-6-CON
r8#NECT: Interface Serial0/0/0:0 is now connected to 180488888002 N/A
Dec 22 18:23:40.443: ISDN Se0/0/0:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0080
r8#
Dec 22 18:23:42.407: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/0:0, changed state to up
r8#
Dec 22 18:23:47.675: %ISDN-6-DISCONNECT: Interface Serial0/0/0:0  disconnected from 180488888002 , call lasted 7 seconds
r8#
Dec 22 18:23:47.675: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x0080
        Cause i = 0x8290 - Normal call clearing
Dec 22 18:23:47.683: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x8080
Dec 22 18:23:47.683: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0080
r8#
r8#sh isdn stat
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
    Layer 3 Status:
Branch2#sh run
voice-card 0
controller T1 0/2/0
no ip address
encapsulation hdlc
no cdp enable
preference 1
port 0/2/0:23
forward-digits all
prefix 1757777
telephony-service
max-ephones 2
max-dn 2
auto assign 1 to 2
dn-webedit
time-webedit
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
    Layer 3 Status:
Branch2#
r8#
                Standard = CCITT
r8#
r8#
r8#
r8#
Everyone's tags (1)
1 ACCEPTED SOLUTION
Green
Re: CME to CME call fails across PRI
On CME R8
Change this dial peer (804) from
preference 1
port 0/0/0:23
forward-digits all
prefix 18048888
to
preference 1
port 0/0/0:23
forward-digits all
prefix 8048888
It will then match the Branch 2 config:-
telephony-service
Also change the dial peer (757) on Branch 2
From
prefix 1757777
To
prefix 757777
Alex
Regards, Alex. Please rate useful posts.
Green
On CME R8
preference 1
port 0/0/0:23
forward-digits all
prefix 18048888
to
preference 1
port 0/0/0:23
forward-digits all
prefix 8048888
telephony-service
From
prefix 1757777
To
prefix 757777
Alex
Hi Alex,
That fixed it. Thanks a lot. What a big help to get me past this hurdle in my labs.
-Mike
516
