Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
cme to cme calls failing
Hi Everyone,
We have two branches (KA and MD) where until yesterday everything was working fine.
Since yesterday when we are calling to MD branch from KA branch only the phones are ringing but when we answer the call the calls are getting disconnected.
Ephone telephone numbers at Md branch are in the range of 40.. and at KA branch are in the range of 11.. and 12..
It would be really helpful if you could find me a solution.
Please find the attached show run configuration of both the brnaches.Also let me know if you need any debugs for these configs.
Everyone's tags (1)
Calls from KA to MD also failing from PSTN ?
Please send  debug ccsip messages and debug voip ccapi inout.
Manish
Rate all the helpful post.
Hi Manish,
Thanks for responding. the calls from ka to md from pstn is not failing. Find the below requested debugs
Madina-BR1-CME#
004368: Dec 29 23:18:19.417: //-1/1883D6D1AEDC/CCAPI/cc_api_display_ie_subfields
   cc_api_call_setup_ind_common:
   cisco-username=192.168.11.160
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=4035
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
004369: Dec 29 23:18:19.417: //-1/1883D6D1AEDC/CCAPI/cc_api_call_setup_ind_commo
   Interface=0x8786AC44, Call Info(
   Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Scree
   Called Number=4035(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=T
   Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALS
004370: Dec 29 23:18:19.417: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004371: Dec 29 23:18:19.417: :cc_get_feature_vsa malloc success
004372: Dec 29 23:18:19.417: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004373: Dec 29 23:18:19.417:  cc_get_feature_vsa count is 3
004374: Dec 29 23:18:19.417: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004375: Dec 29 23:18:19.417: :FEATURE_VSA attributes are: feature_name:0,feature
004376: Dec 29 23:18:19.417: //2336/1883D6D1AEDC/CCAPI/cc_api_call_setup_ind_com
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, P
   Called Number=4035(TON=Unknown, NPI=Unknown))
004377: Dec 29 23:18:19.417: //2336/1883D6D1AEDC/CCAPI/cc_process_call_setup_ind
   Event=0x885EBD68
004378: Dec 29 23:18:19.417: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 4035
004379: Dec 29 23:18:19.417: //2336/1883D6D1AEDC/CCAPI/ccCallSetContext:
   Context=0x8AE77D6C
004380: Dec 29 23:18:19.417: //2336/1883D6D1AEDC/CCAPI/cc_process_call_setup_ind
   >>>>CCAPI handed cid 2336 with tag 0 to app "_ManagedAppProcess_Default"
004381: Dec 29 23:18:19.417: //2336/1883D6D1AEDC/CCAPI/ccCallProceeding:
004382: Dec 29 23:18:19.421: //2336/1883D6D1AEDC/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=FALSE, Mode=0,
   Outgoing Dial-peer=4000, Params=0x8AE7A73C, Progress Indication=NULL(0)
004383: Dec 29 23:18:19.421: //2336/1883D6D1AEDC/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Present
004384: Dec 29 23:18:19.421: //2336/1883D6D1AEDC/CCAPI/ccCheckClipClir:
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presen
004385: Dec 29 23:18:19.421: //2336/1883D6D1AEDC/CCAPI/ccCallSetupRequest:
   Destination Pattern=40[0-4]., Called Number=4035, Digit Strip=FALSE
004386: Dec 29 23:18:19.421: //2336/1883D6D1AEDC/CCAPI/ccCallSetupRequest:
   Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentatio
   Redirect Number=, Display Info=
   Account Number=192.168.11.160, Final Destination Flag=TRUE,
   Guid=1883D6D1-7018-11E3-AEDC-EDB6A4A5D089, Outgoing Dial-peer=4000
004387: Dec 29 23:18:19.421: //2336/1883D6D1AEDC/CCAPI/cc_api_display_ie_subfiel
   ccCallSetupRequest:
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=4035
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
004388: Dec 29 23:18:19.421: //2336/1883D6D1AEDC/CCAPI/ccIFCallSetupRequestPriva
   Interface=0x8786AC44, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screeni
   Called Number=4035(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=40
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Appl
004389: Dec 29 23:18:19.421: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004390: Dec 29 23:18:19.421: :cc_get_feature_vsa malloc success
004391: Dec 29 23:18:19.421: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004392: Dec 29 23:18:19.421:  cc_get_feature_vsa count is 4
004393: Dec 29 23:18:19.421: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004394: Dec 29 23:18:19.421: :FEATURE_VSA attributes are: feature_name:0,feature
004395: Dec 29 23:18:19.421: //2337/1883D6D1AEDC/CCAPI/ccIFCallSetupRequestPriva
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
004396: Dec 29 23:18:19.421: //2337/1883D6D1AEDC/CCAPI/ccCallSetContext:
   Context=0x8AE7A6EC
004397: Dec 29 23:18:19.421: //2336/1883D6D1AEDC/CCAPI/ccSaveDialpeerTag:
004398: Dec 29 23:18:19.425: //2337/1883D6D1AEDC/CCAPI/cc_api_event_indication:
   Event=93, Call Id=2337
004399: Dec 29 23:18:19.425: //2337/1883D6D1AEDC/CCAPI/cc_api_event_indication:
   Event Is Sent To Conferenced SPI(s) Directly
004400: Dec 29 23:18:19.429: //-1/1883D6D1AEDC/CCAPI/cc_api_display_ie_subfields
   cisco-username=192.168.80.160
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=4035
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
004401: Dec 29 23:18:19.429: //-1/1883D6D1AEDC/CCAPI/cc_api_call_setup_ind_commo
004402: Dec 29 23:18:19.429: %CALL_CONTROL-6-CALL_LOOP: The incoming call has a
004403: Dec 29 23:18:19.429: //-1/1883D6D1AEDC/CCAPI/cc_api_call_setup_ind_commo
   SPI Call Setup Request Is Failed
004404: Dec 29 23:18:19.429: //2337/1883D6D1AEDC/CCAPI/cc_api_call_disconnected:
   Cause Value=127, Interface=0x8786AC44, Call Id=2337
004405: Dec 29 23:18:19.429: //2337/1883D6D1AEDC/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=127, Retry Count=0)
004406: Dec 29 23:18:19.433: //2336/1883D6D1AEDC/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
004407: Dec 29 23:18:19.433: //2337/1883D6D1AEDC/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=2337
004408: Dec 29 23:18:19.433: //2337/1883D6D1AEDC/CCAPI/ccCallDisconnect:
   Cause Value=127, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect
004409: Dec 29 23:18:19.433: //2337/1883D6D1AEDC/CCAPI/ccCallDisconnect:
   Cause Value=127, Call Entry(Responsed=TRUE, Cause Value=127)
004410: Dec 29 23:18:19.433: //2337/1883D6D1AEDC/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
004411: Dec 29 23:18:19.433: //2337/1883D6D1AEDC/CCAPI/cc_api_call_disconnect_do
   Disposition=0, Interface=0x8786AC44, Tag=0x0, Call Id=2337,
   Call Entry(Disconnect Cause=127, Voice Class Cause Code=0, Retry Count=0)
004412: Dec 29 23:18:19.433: //2337/1883D6D1AEDC/CCAPI/cc_api_call_disconnect_do
   Call Disconnect Event Sent
004413: Dec 29 23:18:19.433: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004414: Dec 29 23:18:19.433: :cc_free_feature_vsa freeing 8AE4D330
004415: Dec 29 23:18:19.433: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004416: Dec 29 23:18:19.433:  vsacount in free is 3
004417: Dec 29 23:18:19.433: //2336/1883D6D1AEDC/CCAPI/ccCallDisconnect:
004418: Dec 29 23:18:19.433: //2336/1883D6D1AEDC/CCAPI/ccCallDisconnect:
004419: Dec 29 23:18:19.437: //2336/1883D6D1AEDC/CCAPI/cc_api_get_transfer_info:
004420: Dec 29 23:18:19.437: //2336/1883D6D1AEDC/CCAPI/cc_api_call_disconnect_do
   Disposition=0, Interface=0x8786AC44, Tag=0x0, Call Id=2336,
004421: Dec 29 23:18:19.437: //2336/1883D6D1AEDC/CCAPI/cc_api_call_disconnect_do
004422: Dec 29 23:18:19.437: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004423: Dec 29 23:18:19.437: :cc_free_feature_vsa freeing 8AE4C7D0
004424: Dec 29 23:18:19.437: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004425: Dec 29 23:18:19.437:  vsacount in free is 2
Hi.
In Medina-Br1-Cme please shut dial-peer 4000 and try again.
Please , after shutdown, please resend the debug output.
Regards.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Hello Abdul,
There is loop on the call 004402: Dec 29 23:18:19.429: %CALL_CONTROL-6-CALL_LOOP: , this is IOS feature which prevent any loop on gateway.
Please check any new configuration applied to any of these gateway (specially dial-peer) or any new set up made (like putting a new gw on network) , which in result creating a new route or pointing to inbound dial-peer.
This generally occurs because of overlapping dial-peer , please verify any overlapping dial-peer ,remove it and then test.
Manish
I have removed the dial-peer 4000 and still the problem persists find the ccapi output after removing:
Madina-BR1-CME#
004821: Dec 30 11:49:10.974: //-1/FDE37900BEAA/CCAPI/cc_api_display_ie_subfields:
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=4034
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
004822: Dec 30 11:49:10.974: //-1/FDE37900BEAA/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=4034(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=2468
004823: Dec 30 11:49:10.974: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004824: Dec 30 11:49:10.974: :cc_get_feature_vsa malloc success
004825: Dec 30 11:49:10.974: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004826: Dec 30 11:49:10.974:  cc_get_feature_vsa count is 3
004827: Dec 30 11:49:10.974: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004828: Dec 30 11:49:10.974: :FEATURE_VSA attributes are: feature_name:0,feature_time:2330252088,feature_id:2062
004829: Dec 30 11:49:10.974: //2468/FDE37900BEAA/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=4034(TON=Unknown, NPI=Unknown))
004830: Dec 30 11:49:10.974: //2468/FDE37900BEAA/CCAPI/cc_process_call_setup_ind:
   Event=0x885EC860
004831: Dec 30 11:49:10.974: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 4034
004832: Dec 30 11:49:10.974: //2468/FDE37900BEAA/CCAPI/ccCallSetContext:
   Context=0x8AE77D6C
004833: Dec 30 11:49:10.974: //2468/FDE37900BEAA/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 2468 with tag 0 to app "_ManagedAppProcess_Default"
004834: Dec 30 11:49:10.978: //2468/FDE37900BEAA/CCAPI/ccCallProceeding:
004835: Dec 30 11:49:10.978: //2468/FDE37900BEAA/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=20004, Params=0x8AE7013C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
004836: Dec 30 11:49:10.978: //2468/FDE37900BEAA/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
004837: Dec 30 11:49:10.978: //2468/FDE37900BEAA/CCAPI/ccCheckClipClir:
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
004838: Dec 30 11:49:10.978: //2468/FDE37900BEAA/CCAPI/ccCallSetupRequest:
   Destination Pattern=4034$, Called Number=4034, Digit Strip=TRUE
004839: Dec 30 11:49:10.978: //2468/FDE37900BEAA/CCAPI/ccCallSetupRequest:
   Guid=FDE37900-7080-11E3-BEAA-EDB6A4A5D089, Outgoing Dial-peer=20004
004840: Dec 30 11:49:10.978: //2468/FDE37900BEAA/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=4034
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
004841: Dec 30 11:49:10.978: //2468/FDE37900BEAA/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x8966B7D4, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=4034(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20004, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
004842: Dec 30 11:49:10.978: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004843: Dec 30 11:49:10.978: :cc_get_feature_vsa malloc success
004844: Dec 30 11:49:10.978: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004845: Dec 30 11:49:10.978:  cc_get_feature_vsa count is 4
004846: Dec 30 11:49:10.978: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004847: Dec 30 11:49:10.978: :FEATURE_VSA attributes are: feature_name:0,feature_time:2330248504,feature_id:2063
004848: Dec 30 11:49:10.982: //2469/FDE37900BEAA/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
004849: Dec 30 11:49:10.982: //2469/FDE37900BEAA/CCAPI/ccCallSetContext:
   Context=0x8AE700EC
004850: Dec 30 11:49:10.982: //2468/FDE37900BEAA/CCAPI/ccSaveDialpeerTag:
004851: Dec 30 11:49:10.982: //2469/FDE37900BEAA/CCAPI/cc_api_update_call_info:
   Interface=0x8966B7D4, Call Id=0x9A5
004852: Dec 30 11:49:10.982: //2469/FDE37900BEAA/CCAPI/cc_api_call_proceeding:
   Interface=0x8966B7D4, Progress Indication=NULL(0)
004853: Dec 30 11:49:10.986: //2469/FDE37900BEAA/CCAPI/cc_api_call_alert:
   Interface=0x8966B7D4, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
004854: Dec 30 11:49:10.986: //2469/FDE37900BEAA/CCAPI/cc_api_call_alert:
   Call Entry(Retry Count=0, Responsed=TRUE)
004855: Dec 30 11:49:10.986: //2468/FDE37900BEAA/CCAPI/ccCallAlert:
004856: Dec 30 11:49:10.990: //2468/FDE37900BEAA/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
004857: Dec 30 11:49:10.990: //2469/FDE37900BEAA/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
004858: Dec 30 11:49:10.990: //2469/FDE37900BEAA/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=2469
004859: Dec 30 11:49:10.990: //2468/FDE37900BEAA/CCAPI/cc_api_get_delay_xport:
   CallInfo(delay xport=FALSE)
004860: Dec 30 11:49:10.994: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x8864B28C, Interface Type=6, Destination=, Mode=0x0,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
004861: Dec 30 11:49:10.994: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004862: Dec 30 11:49:10.994: :cc_get_feature_vsa malloc success
004863: Dec 30 11:49:10.994: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004864: Dec 30 11:49:10.994:  cc_get_feature_vsa count is 5
004865: Dec 30 11:49:10.994: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004866: Dec 30 11:49:10.994: :FEATURE_VSA attributes are: feature_name:0,feature_time:2330248280,feature_id:2064
004867: Dec 30 11:49:10.994: //2470/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
004868: Dec 30 11:49:10.994: //2470/xxxxxxxxxxxx/CCAPI/cc_api_call_proceeding:
   Interface=0x8864B28C, Progress Indication=NULL(0)
004869: Dec 30 11:49:10.994: //2470/xxxxxxxxxxxx/CCAPI/cc_api_call_alert:
   Interface=0x8864B28C, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
004870: Dec 30 11:49:10.994: //2470/xxxxxxxxxxxx/CCAPI/cc_api_call_alert:
004871: Dec 30 11:49:10.998: //2470/xxxxxxxxxxxx/CCAPI/ccCallFeature:
   Feature Type=12, Call Id=2470
004872: Dec 30 11:49:10.998: //2470/xxxxxxxxxxxx/CCAPI/cc_api_call_alert:
004873: Dec 30 11:49:10.998: //2470/xxxxxxxxxxxx/CCAPI/cc_api_call_alert:
004874: Dec 30 11:49:16.126: //2468/FDE37900BEAA/CCAPI/cc_api_call_disconnected:
   Cause Value=41, Interface=0x8786AC44, Call Id=2468
004875: Dec 30 11:49:16.126: //2468/FDE37900BEAA/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=41, Retry Count=0)
004876: Dec 30 11:49:16.126: //2469/FDE37900BEAA/CCAPI/ccCallDisconnect:
   Cause Value=41, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
004877: Dec 30 11:49:16.130: //2469/FDE37900BEAA/CCAPI/ccCallDisconnect:
   Cause Value=41, Call Entry(Responsed=TRUE, Cause Value=41)
004878: Dec 30 11:49:16.130: //2469/FDE37900BEAA/CCAPI/cc_api_get_transfer_info:
004879: Dec 30 11:49:16.130: //2468/FDE37900BEAA/CCAPI/ccCallDisconnect:
   Cause Value=41, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=41)
004880: Dec 30 11:49:16.130: //2468/FDE37900BEAA/CCAPI/ccCallDisconnect:
004881: Dec 30 11:49:16.130: //2468/FDE37900BEAA/CCAPI/cc_api_get_transfer_info:
004882: Dec 30 11:49:16.130: //2468/FDE37900BEAA/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x8786AC44, Tag=0x0, Call Id=2468,
   Call Entry(Disconnect Cause=41, Voice Class Cause Code=0, Retry Count=0)
004883: Dec 30 11:49:16.130: //2468/FDE37900BEAA/CCAPI/cc_api_call_disconnect_done:
004884: Dec 30 11:49:16.130: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004885: Dec 30 11:49:16.130: :cc_free_feature_vsa freeing 8AE4D330
004886: Dec 30 11:49:16.130: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004887: Dec 30 11:49:16.130:  vsacount in free is 4
004888: Dec 30 11:49:16.134: //2469/FDE37900BEAA/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x8966B7D4, Tag=0x0, Call Id=2469,
004889: Dec 30 11:49:16.134: //2469/FDE37900BEAA/CCAPI/cc_api_call_disconnect_done:
004890: Dec 30 11:49:16.134: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004891: Dec 30 11:49:16.134: :cc_free_feature_vsa freeing 8AE4C530
004892: Dec 30 11:49:16.134: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004893: Dec 30 11:49:16.134:  vsacount in free is 3
004894: Dec 30 11:49:16.138: //2470/xxxxxxxxxxxx/CCAPI/ccCallFeature:
   Feature Type=34, Call Id=2470
004895: Dec 30 11:49:16.138: //2470/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
004896: Dec 30 11:49:16.138: //2470/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
004897: Dec 30 11:49:16.138: //2470/xxxxxxxxxxxx/CCAPI/cc_api_get_transfer_info:
004898: Dec 30 11:49:16.142: //2470/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x8864B28C, Tag=0x0, Call Id=2470,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
004899: Dec 30 11:49:16.142: //2470/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
004900: Dec 30 11:49:16.142: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004901: Dec 30 11:49:16.142: :cc_free_feature_vsa freeing 8AE4C450
004902: Dec 30 11:49:16.142: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004903: Dec 30 11:49:16.142:  vsacount in free is 2
Hi.
Can you please try a call to extension 4014 and send the output of a debug ccapi inout?
Carlo
Hi carlo
thanks for taking interest in solving my issue. Please find the below requested debug
004904: Dec 30 12:42:32.546: //-1/7227AD92BF8D/CCAPI/cc_api_display_ie_subfields:
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=4014
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
004905: Dec 30 12:42:32.546: //-1/7227AD92BF8D/CCAPI/cc_api_call_setup_ind_common:
   Called Number=4014(TON=Unknown, NPI=Unknown),
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=2471
004906: Dec 30 12:42:32.546: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004907: Dec 30 12:42:32.546: :cc_get_feature_vsa malloc success
004908: Dec 30 12:42:32.546: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004909: Dec 30 12:42:32.550:  cc_get_feature_vsa count is 3
004910: Dec 30 12:42:32.550: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004911: Dec 30 12:42:32.550: :FEATURE_VSA attributes are: feature_name:0,feature_time:2330248280,feature_id:2065
004912: Dec 30 12:42:32.550: //2471/7227AD92BF8D/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Called Number=4014(TON=Unknown, NPI=Unknown))
004913: Dec 30 12:42:32.550: //2471/7227AD92BF8D/CCAPI/cc_process_call_setup_ind:
   Event=0x885EC860
004914: Dec 30 12:42:32.550: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 4014
004915: Dec 30 12:42:32.550: //2471/7227AD92BF8D/CCAPI/ccCallSetContext:
   Context=0x8AE72A6C
004916: Dec 30 12:42:32.550: //2471/7227AD92BF8D/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 2471 with tag 0 to app "_ManagedAppProcess_Default"
004917: Dec 30 12:42:32.550: //2471/7227AD92BF8D/CCAPI/ccCallProceeding:
004918: Dec 30 12:42:32.554: //2471/7227AD92BF8D/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=20019, Params=0x8AE715FC, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
004919: Dec 30 12:42:32.554: //2471/7227AD92BF8D/CCAPI/ccCheckClipClir:
004920: Dec 30 12:42:32.554: //2471/7227AD92BF8D/CCAPI/ccCheckClipClir:
004921: Dec 30 12:42:32.554: //2471/7227AD92BF8D/CCAPI/ccCallSetupRequest:
   Destination Pattern=4014$, Called Number=4014, Digit Strip=TRUE
004922: Dec 30 12:42:32.554: //2471/7227AD92BF8D/CCAPI/ccCallSetupRequest:
   Guid=7227AD92-7088-11E3-BF8D-EDB6A4A5D089, Outgoing Dial-peer=20019
004923: Dec 30 12:42:32.554: //2471/7227AD92BF8D/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=4014
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
004924: Dec 30 12:42:32.554: //2471/7227AD92BF8D/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x895D9D10, Interface Type=6, Destination=, Mode=0x0,
   Called Number=4014(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20019, Call Count On=FALSE,
004925: Dec 30 12:42:32.554: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004926: Dec 30 12:42:32.554: :cc_get_feature_vsa malloc success
004927: Dec 30 12:42:32.554: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004928: Dec 30 12:42:32.554:  cc_get_feature_vsa count is 4
004929: Dec 30 12:42:32.554: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004930: Dec 30 12:42:32.554: :FEATURE_VSA attributes are: feature_name:0,feature_time:2330248504,feature_id:2066
004931: Dec 30 12:42:32.554: //2472/7227AD92BF8D/CCAPI/ccIFCallSetupRequestPrivate:
004932: Dec 30 12:42:32.554: //2472/7227AD92BF8D/CCAPI/ccCallSetContext:
   Context=0x8AE715AC
004933: Dec 30 12:42:32.554: //2471/7227AD92BF8D/CCAPI/ccSaveDialpeerTag:
004934: Dec 30 12:42:32.554: //2472/7227AD92BF8D/CCAPI/cc_api_update_call_info:
   Interface=0x895D9D10, Call Id=0x9A8
004935: Dec 30 12:42:32.558: //2472/7227AD92BF8D/CCAPI/cc_api_call_proceeding:
   Interface=0x895D9D10, Progress Indication=NULL(0)
004936: Dec 30 12:42:32.558: //2472/7227AD92BF8D/CCAPI/cc_api_call_alert:
   Interface=0x895D9D10, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
004937: Dec 30 12:42:32.558: //2472/7227AD92BF8D/CCAPI/cc_api_call_alert:
004938: Dec 30 12:42:32.562: //2471/7227AD92BF8D/CCAPI/ccCallAlert:
004939: Dec 30 12:42:32.562: //2471/7227AD92BF8D/CCAPI/ccCallAlert:
004940: Dec 30 12:42:32.562: //2472/7227AD92BF8D/CCAPI/cc_api_get_called_ccm_detected:
004941: Dec 30 12:42:32.562: //2472/7227AD92BF8D/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=2472
004942: Dec 30 12:42:32.562: //2471/7227AD92BF8D/CCAPI/cc_api_get_delay_xport:
004943: Dec 30 12:42:37.658: //2471/7227AD92BF8D/CCAPI/cc_api_call_disconnected:
   Cause Value=41, Interface=0x8786AC44, Call Id=2471
004944: Dec 30 12:42:37.658: //2471/7227AD92BF8D/CCAPI/cc_api_call_disconnected:
004945: Dec 30 12:42:37.658: //2472/7227AD92BF8D/CCAPI/ccCallDisconnect:
004946: Dec 30 12:42:37.658: //2472/7227AD92BF8D/CCAPI/ccCallDisconnect:
004947: Dec 30 12:42:37.658: //2472/7227AD92BF8D/CCAPI/cc_api_get_transfer_info:
004948: Dec 30 12:42:37.662: //2471/7227AD92BF8D/CCAPI/ccCallDisconnect:
004949: Dec 30 12:42:37.662: //2471/7227AD92BF8D/CCAPI/ccCallDisconnect:
004950: Dec 30 12:42:37.662: //2471/7227AD92BF8D/CCAPI/cc_api_get_transfer_info:
004951: Dec 30 12:42:37.662: //2471/7227AD92BF8D/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x8786AC44, Tag=0x0, Call Id=2471,
004952: Dec 30 12:42:37.662: //2471/7227AD92BF8D/CCAPI/cc_api_call_disconnect_done:
004953: Dec 30 12:42:37.662: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004954: Dec 30 12:42:37.662: :cc_free_feature_vsa freeing 8AE4C450
004955: Dec 30 12:42:37.662: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004956: Dec 30 12:42:37.662:  vsacount in free is 3
004957: Dec 30 12:42:37.666: //2472/7227AD92BF8D/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x895D9D10, Tag=0x0, Call Id=2472,
004958: Dec 30 12:42:37.666: //2472/7227AD92BF8D/CCAPI/cc_api_call_disconnect_done:
004959: Dec 30 12:42:37.666: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004960: Dec 30 12:42:37.666: :cc_free_feature_vsa freeing 8AE4C530
004961: Dec 30 12:42:37.666: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004962: Dec 30 12:42:37.666:  vsacount in free is 2
Hi.
In Medina CME, add:
voice service voip
no ip address trusted list
h323
call start slow
On Kakia CME
dial-peer voice 4000
dtmf-relay h245-alphanumeric
no vad
And send debug
Carlo
Please find the debugs after the requested changes:
Madina-BR1-CME#debug voice ccapi inout
voip ccapi inout debugging is on
Madina-BR1-CME#term mon
Madina-BR1-CME#
005110: Dec 30 13:30:37.937: //-1/2A117E9080A4/CCAPI/cc_api_display_ie_subfields:
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=4014
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
005111: Dec 30 13:30:37.937: //-1/2A117E9080A4/CCAPI/cc_api_call_setup_ind_common:
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=2477
005112: Dec 30 13:30:37.937: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
005113: Dec 30 13:30:37.937: :cc_get_feature_vsa malloc success
005114: Dec 30 13:30:37.937: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
005115: Dec 30 13:30:37.937:  cc_get_feature_vsa count is 3
005116: Dec 30 13:30:37.937: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
005117: Dec 30 13:30:37.937: :FEATURE_VSA attributes are: feature_name:0,feature_time:2330248280,feature_id:2071
005118: Dec 30 13:30:37.937: //2477/2A117E9080A4/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
005119: Dec 30 13:30:37.937: //2477/2A117E9080A4/CCAPI/cc_process_call_setup_ind:
   Event=0x885ED358
005120: Dec 30 13:30:37.937: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
005121: Dec 30 13:30:37.937: //2477/2A117E9080A4/CCAPI/ccCallSetContext:
   Context=0x8AE6D76C
005122: Dec 30 13:30:37.937: //2477/2A117E9080A4/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 2477 with tag 0 to app "_ManagedAppProcess_Default"
005123: Dec 30 13:30:37.937: //2477/2A117E9080A4/CCAPI/ccCallProceeding:
005124: Dec 30 13:30:37.941: //2477/2A117E9080A4/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=20019, Params=0x8AE6EC7C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
005125: Dec 30 13:30:37.941: //2477/2A117E9080A4/CCAPI/ccCheckClipClir:
005126: Dec 30 13:30:37.941: //2477/2A117E9080A4/CCAPI/ccCheckClipClir:
005127: Dec 30 13:30:37.941: //2477/2A117E9080A4/CCAPI/ccCallSetupRequest:
005128: Dec 30 13:30:37.941: //2477/2A117E9080A4/CCAPI/ccCallSetupRequest:
   Guid=2A117E90-708F-11E3-80A4-EDB6A4A5D089, Outgoing Dial-peer=20019
005129: Dec 30 13:30:37.941: //2477/2A117E9080A4/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=4014
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
005130: Dec 30 13:30:37.941: //2477/2A117E9080A4/CCAPI/ccIFCallSetupRequestPrivate:
005131: Dec 30 13:30:37.941: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
005132: Dec 30 13:30:37.941: :cc_get_feature_vsa malloc success
005133: Dec 30 13:30:37.941: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
005134: Dec 30 13:30:37.941:  cc_get_feature_vsa count is 4
005135: Dec 30 13:30:37.941: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
005136: Dec 30 13:30:37.941: :FEATURE_VSA attributes are: feature_name:0,feature_time:2330248504,feature_id:2072
005137: Dec 30 13:30:37.941: //2478/2A117E9080A4/CCAPI/ccIFCallSetupRequestPrivate:
005138: Dec 30 13:30:37.941: //2478/2A117E9080A4/CCAPI/ccCallSetContext:
   Context=0x8AE6EC2C
005139: Dec 30 13:30:37.941: //2477/2A117E9080A4/CCAPI/ccSaveDialpeerTag:
005140: Dec 30 13:30:37.945: //2478/2A117E9080A4/CCAPI/cc_api_update_call_info:
   Interface=0x895D9D10, Call Id=0x9AE
005141: Dec 30 13:30:37.945: //2478/2A117E9080A4/CCAPI/cc_api_call_proceeding:
005142: Dec 30 13:30:37.949: //2478/2A117E9080A4/CCAPI/cc_api_call_alert:
005143: Dec 30 13:30:37.949: //2478/2A117E9080A4/CCAPI/cc_api_call_alert:
005144: Dec 30 13:30:37.949: //2477/2A117E9080A4/CCAPI/ccCallAlert:
005145: Dec 30 13:30:37.949: //2477/2A117E9080A4/CCAPI/ccCallAlert:
005146: Dec 30 13:30:37.949: //2478/2A117E9080A4/CCAPI/cc_api_get_called_ccm_detected:
005147: Dec 30 13:30:37.949: //2478/2A117E9080A4/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=2478
005148: Dec 30 13:30:37.953: //2477/2A117E9080A4/CCAPI/cc_api_get_delay_xport:
005149: Dec 30 13:30:43.085: //2477/2A117E9080A4/CCAPI/cc_api_call_disconnected:
   Cause Value=41, Interface=0x8786AC44, Call Id=2477
005150: Dec 30 13:30:43.085: //2477/2A117E9080A4/CCAPI/cc_api_call_disconnected:
005151: Dec 30 13:30:43.085: //2478/2A117E9080A4/CCAPI/ccCallDisconnect:
005152: Dec 30 13:30:43.085: //2478/2A117E9080A4/CCAPI/ccCallDisconnect:
005153: Dec 30 13:30:43.085: //2478/2A117E9080A4/CCAPI/cc_api_get_transfer_info:
005154: Dec 30 13:30:43.089: //2477/2A117E9080A4/CCAPI/ccCallDisconnect:
005155: Dec 30 13:30:43.089: //2477/2A117E9080A4/CCAPI/ccCallDisconnect:
005156: Dec 30 13:30:43.089: //2477/2A117E9080A4/CCAPI/cc_api_get_transfer_info:
005157: Dec 30 13:30:43.089: //2477/2A117E9080A4/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x8786AC44, Tag=0x0, Call Id=2477,
005158: Dec 30 13:30:43.089: //2477/2A117E9080A4/CCAPI/cc_api_call_disconnect_done:
005159: Dec 30 13:30:43.089: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
005160: Dec 30 13:30:43.089: :cc_free_feature_vsa freeing 8AE4C450
005161: Dec 30 13:30:43.089: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
005162: Dec 30 13:30:43.089:  vsacount in free is 3
005163: Dec 30 13:30:43.093: //2478/2A117E9080A4/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x895D9D10, Tag=0x0, Call Id=2478,
005164: Dec 30 13:30:43.093: //2478/2A117E9080A4/CCAPI/cc_api_call_disconnect_done:
005165: Dec 30 13:30:43.093: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
005166: Dec 30 13:30:43.093: :cc_free_feature_vsa freeing 8AE4C530
005167: Dec 30 13:30:43.093: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
005168: Dec 30 13:30:43.093:  vsacount in free is 2
Hi.
Please send also a debug ccapi inout from Kakia CME.
Carlo
kakia cme debugs calling 4014 of madina_cme
CME-KAKIA#csim start 4014
Dec 30 13:56:36.067: csim: called number = 4014, loop count = 1 ping count = 0
Dec 30 13:56:36.067: csimSetupPeer peer type(2), destPat(4014), matched(3), targ
Dec 30 13:56:36.067: //-1/xxxxxxxxxxxx/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=4000, Params=0x17BEEB64, Progress Indication=NULL(0)
Dec 30 13:56:36.067: //-1/xxxxxxxxxxxx/CCAPI/ccCheckClipClir:
   Destination Pattern=40[0-4]., Called Number=4014, Digit Strip=FALSE
   Account Number=, Final Destination Flag=FALSE,
   Guid=08283D7D-7091-11E3-8109-EDB6A4A5D089, Outgoing Dial-peer=4000
Dec 30 13:56:36.067: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=4014
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Dec 30 13:56:36.067: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x12FECC98, Interface Type=1, Destination=, Mode=0x0,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=4000, Ca
Dec 30 13:56:36.067: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Dec 30 13:56:36.067: :cc_get_feature_vsa malloc success
Dec 30 13:56:36.067:  cc_get_feature_vsa count is 3
Dec 30 13:56:36.067: :FEATURE_VSA attributes are: feature_name:0,feature_time:39
Dec 30 13:56:36.067: //103257/08283D7D8109/CCAPI/ccIFCallSetupRequestPrivate:
Dec 30 13:56:36.067: //103257/08283D7D8109/CCAPI/ccCallSetContext:
   Context=0x17CFE90
Dec 30 13:56:36.207: //103257/08283D7D8109/CCAPI/ccIsInfoRingback:
   Returning dpRingBack=0
Dec 30 13:56:36.207: //103257/08283D7D8109/CCAPI/cc_api_call_proceeding:
   Interface=0x12FECC98, Progress Indication=NULL(0)
Dec 30 13:56:36.207: csim_do_test: cid(103257), ev(23), disp(0)
Dec 30 13:56:36.207: csimTraceSct: cid(103257),st(0),oldst(0)
Dec 30 13:56:36.207: csimIgnore  cid(103257), st(0),oldst(0), ev(23)
Dec 30 13:56:36.207: //103257/08283D7D8109/CCAPI/cc_api_call_alert:
   Interface=0x12FECC98, Progress Indication=NULL(0), Signal Indication=SIGNAL R
Dec 30 13:56:36.211: //103257/08283D7D8109/CCAPI/cc_api_call_alert:
Dec 30 13:56:36.211: csim_do_test: cid(103257), ev(8), disp(0)
Dec 30 13:56:36.211: csimTraceSct: cid(103257),st(0),oldst(0)
Dec 30 13:56:36.211: csimIgnore  cid(103257), st(0),oldst(0), ev(8)
Dec 30 13:56:41.207: //103257/08283D7D8109/CCAPI/cc_api_call_disconnected:
   Cause Value=41, Interface=0x12FECC98, Call Id=103257
Dec 30 13:56:41.207: csim_do_test: cid(103257), ev(12), disp(0)
Dec 30 13:56:41.207: csimTraceSct: cid(103257),st(0),oldst(0)
Dec 30 13:56:41.207: csim err csimDisconnected recvd DISC cid(103257)
Dec 30 13:56:41.207: //103257/08283D7D8109/CCAPI/ccCallDisconnect:
Dec 30 13:56:41.207: //103257/08283D7D8109/CCAPI/cc_api_get_transfer_info:
Dec 30 13:56:41.207: //103257/08283D7D8109/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x12FECC98, Tag=0x0, Call Id=103257,
Dec 30 13:56:41.207: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
CME-KAKIA#
Dec 30 13:56:41.207: :cc_free_feature_vsa freeing 17A059E8
Dec 30 13:56:41.207:  vsacount in free is 2
Dec 30 13:56:41.207: csim_do_test: cid(103257), ev(13), disp(0)
Dec 30 13:56:41.207: csimTraceSct: cid(103257),st(2),oldst(0)
Dec 30 13:56:41.707: csim: loop = 1, failed = 1
Dec 30 13:56:41.707: csim: call attempted = 1, setup failed = 1, tone failed = 0
Dec 30 13:56:41.707: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
   ccAppShutdownMode: remove it from the queue
CME-KAKIA#
Hi.
Is possible to have a trace of a real call not from csim start?
Thank a lot
Carlo
Will take some time as nobody is present on site....as soon as they arive will let you know with debugs.
778
