CME to CUCM SIP Trunk. Incoming Calls
Hi All,
I am currently working on a new CME integration (my first one) and want to ensure I am on the right path.
I have a SIP Trunk running from CME to CUCM and OUTGOING calls are working fine. I have not added any INCOMING dial-peers (or any other configuration). Was looking for some help getting the basics going for this part of the config.
This is a very basic configuration and will not use any PSTN connections (only 4 digit through SIP to CUCM.
Here is what I have so far.
version 15.2
hostname C2901-BaseCamp
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
no ipv6 cef
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.16.240 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address dhcp
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:gui
ip route 0.0.0.0 0.0.0.0 192.168.16.254
ip access-list extended OUTBOUND
permit ip any any
tftp-server flash:ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:ringtones/RingList.xml alias RingList.xml
control-plane
mgcp profile default
dial-peer voice 101 voip
destination-pattern [1-9]...
session protocol sipv2
session target ipv4:192.168.111.20
codec g711ulaw
gatekeeper
shutdown
telephony-service
max-ephones 25
max-dn 25
ip source-address 192.168.16.240 port 2000
cnf-file location flash:
load 7960-7940 P0030801SR02
load 7941 P00308000500.loads
load 7942 P00308000500.loads
max-conferences 4 gain -6
web admin system name cmeadmin secret 5 $1$yiLi$93qNASlvu5gkGlle2Awux.
dn-webedit
time-webedit
transfer-system full-consult
ephone-dn  1
number 2575
name Base Camp 1
ephone-dn  2
number 2576
name Base Camp 2
ephone-dn  3
number 2576
name Base Camp 3
ephone  1
mac-address 001B.2A89.511E
type 7940
button  1:1
ephone  2
mac-address 001B.0CDB.36B3
type 7940
button  1:2
Everyone's tags (6)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Yup, that would be next thing to check. You can add the IPs there, disable it completely or add dial-peer with destination pattern of CUCM server.
For troubleshotting use "debug ccsip messages".
HTH, please rate all useful posts!
Chris
If you don't add any dial-peers default dial peer 0 will be used for incoming calls, the only thing to keep in mind about default dial peer is that it will use G711 codec. You can modify your existing dial peer as following to use it for inbound as well:
incoming caller-number .
Chris
Hi Chris,
I have added -
incoming called-number .
Still facing the same issue.
Was the new Toll Fraud applicaiton that was causing the issue.
Resolved! Thanks
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080b3e123.shtml#t3
Chris
2048
