CME Translation Rule issue
i have CME run om 3945 router with IOS c3900-universalk9-mz.SPA.152-4.M2.bin and we apply translation rule for the incoming and the outgoing calls through E1 and we configured the translation profile under the dial peers , the issue is every random period of time and always we face it first working day after the weed end that the translation profile under the dial peers removed automatically and the calls can't done , so every time we have to reconfigure the translation profile under the dial peer , any one can help ?
did youwr memare you shure
did you
wr mem
are you shure router was not reloaded ?
what is ib logg?
sh logg
sh inv
sh ver
sh runn
sure we saved , and find
sure we saved , and find attached show ver  and show inv output but i don't have now sh logg
Hi.Can you please also share
Hi.
Can you please also share your running config?
Carlo
Please rate all helpful posts "The more you help the more you learn"
kindly find attached , i am
i am planing to upgrade the IOS version , is there any recommendation about it to not face any  problem with the configuration or files on the flash or the router license ,
thanks ....
it looks like your outgoing
it looks like your outgoing calls go throw fxo cards not e1
and incoming too
may be somebody can see better
no , it is going through the
no , it is going through the E1
75
