CME Translation rules
Been trying to get the correct translation-rules, but it seems not to be as easy as its on the guide..
I got some going, but I'm still having issues with the outgoing call.. The carrier requires that number format 1-XXX-XXX-XXXX, however I have a 9 for outside calls, and call are still going with 9xxxx no mater how a change the combinations..
I'm having some troube of getting  the 911 service configured as well.. extensions are 10,11,12,13,14 and main number is (not actual#) 2013010000 which I need to dispaly on the all outbound calls, and 911, 411 dp if possible.. This is my current config (don't ) :
voice translation-rule 1
rule 1 /2013010000/ /10/
rule 2 /91/ /1/
rule 3 /9/ /1/
voice translation-rule 2
rule 1 /^9201/ /201/
rule 2 /10/ /2013010000/
rule 3 /91/ /1/
rule 4 /9/ /1/
voice translation-profile DID-to-Ext
translate calling 1
translate called 1
voice translation-profile Ext-to-DID
translate calling 2
translate called 2
translate redirect-target 2
Thanks for reading it
Hall of Fame Super Gold
Now apply to the translation-profile to dial-peer.
Re: CME Translation rules
I already did, still having issues with the outbound calls.when 9XXXXXXXXX dialing..
Then something is not configured right.
There are debugs fro dial-peer and translation to troubleshoot.
Actually I had to add the 9..........  statement on the DP and it was working fine now..
Thx
1021
