Community Member
CME URL Idle for SIP handsets
Hi All,
Anyone know if the below command has a SIP equivalent?
telephony-service
url idle http://XXX/idle.php idle-timeout 5
Trying to get the SIP handsets (9971) to display the same page as the SCCP phones.
VIP Super Bronze
Check under voice register global. I don't have a CME box in front of me but at least url directory exists there in the CME Admin Guide; I would expect other keywords to as well.
conf t
Please remember to rate helpful responses and identify helpful or correct answers.
Community Member
Hi Jonathan, thank you for the response.  I've tried that but there's no such commands under "voice register global", nothing seemed remotely close to it.
CME(config-register-global)#?
voice register global configuration commands:
  application              Define application
  attempted-registrations  Define size of the attempted-registrations table
  authenticate             Define auth mode for SIP CME/SRST
  bandwidth                allow SIP SDP bandwidth related options
  call-forward             Decide call forward parameters for an SIP phone
  default                  Set a command to its defaults
  dialplan-pattern         Define E.164 telephone number prefix
  exit                     Exit from voice register global configuration mode
  external-ring            Set external ringing to be included into alert-info
  fac                      Voice register global FAC setup
  ip                       Set ip packet options
  max-dn                   Define max number of dn
  max-pool                 Define max number of pool
  mode                     Define mode: CME/SRST
  mwi                      MWI service in SRST mode
  no                       Negate a command or set its defaults
  outbound-proxy           Configure an Outbound Proxy Server
  overlap-signal           Configure Overlap Signaling support
  service                  Service configuration in voice reg global
  system                   Define system message
  timeouts                 Define timeout value for sip phone
  timezone                 Set timezone for SIP Phones
I have tried putting it under "telephony-service" but being a SIP phone it didn't pick it up there.
I'm ok if it's not supported under CME but just wanted some confirmation.
Silver
Michael,
This guide- http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_u1ht.html#wp1016489
shows that some CME versions have a URL command under voice register global but it doesn't seem that it there is idle URL in any CME version for SIP.
It may just be one of the things that applies from telephony service.  Did you try regenerating the CNF Files afterwards?
Brian
Community Member
Hi Brian, sorry previous output I didn't fully enable SIP.  URL command does exist and after drilling deeper into the command there doesn't seemed to be anything related to idle URL.
I did regenerate CNF Files and SIP profiles after enabling it under "telephony service", I rebooted the handsets too but they don't seemed to acknowledge "url idle".
The php script is dedinately valid, I tried enabling it under the "service url" button and the 9971 would correctly load the page after pressing the service button.
  apply-config             apply config for the 99/89 phones, restart all other sip phones
  bulk                     Define a pattern for bulk registration
  call-feature-uri         Define TNP SIP phone's Call Feature URI
  camera                   Enable camera
  conference               Configure conference type for adhoc
  create                   Create profile for SIP phone
  date-format              Set date format for IP Phone display
  dst                      Enable / define daylight saving time
  file                     Enable generation of the text profile
  forwarding               Decide if forwarding local is enabled for SIP phone
  hold-alert               Enable On-Hold alert for SIP phone
  load                     Select the firmware load file
  logo                     Define logo url that will be used by SIP phone
  mwi                      Generate stutter tone for SIP mwi
  network-locale           Define network locale
  ntp-server               Define NTP server address for TNP phones
  olsontimezone            Set olson timezone for IP Phones
  phone-redirect-limit     Define max number of redirect per call for SIP phone
  privacy                  Enable privacy for SIP shared-line phone
  privacy-on-hold          Enable privacy-on-hold for SIP shared-line phone
  reset                    Reset all SIP phones
  restart                  restart all SIP phone
  source-address           Define IP address and port for SIP CME
  tftp-path                Define tftp path for SIP CME
  time-format              Set time format for IP Phone display
  upgrade                  Generate OS79XX.TXT for firmware upgrade
  url                      Define SIP phone URL's
  user-locale              Define SIP Phone user locale
  video                    Enable video
  voicemail                Set the voicemail access number called when the messages button is pressed
CME(config-register-global)#url ?
  authentication  authentication url
  directory       directory url
  service         service url
585
