Community Member
CME- utility configuration
hello,
i want to configure a CME for the first time. i would ask if there is any utility that i can use to configure CME easily ( like web utility..).
Menay thanks
Hicham
1 REPLY
Re: CME- utility configuration
If you have a UC520 you can try Configuration Assistant.
Otherwise, this is the most basic configuration you can use to get CME to work (to save some documentation time):
telephony-service
ip source-address A.B.C.D
max-dn X
max-ephones X
ephone-dn 1
number 1000
ephone 1
mac AAAA.BBBB.CCCC
type
button 1:1
You can use the CME GUI as well.
Here is the CLI admin guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmenetwk.html
Enabling the GUI:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmegui.html
You can also use Cisco Configuration Professional. This is the addition to the UC520 version of Configuration Assistant. I'll be honest - never used this. I know the CLI, however. Here's the product guide, download link is towards the right:
http://www.cisco.com/en/US/products/ps9422/index.html
hth,
nick
105
