Community Member
CME v8 - Help (?) Button on Phone support
Annoying issue that I'm running into. The Help (Green ? button) on my phone does not work properly - Press it once it says "Choose an option..for help" but pressing a 2nd button does nothing.
Is this option supported yet in CME 8.0? If so, where do I start to configure this?
Opinions are appreciated!
Everyone's tags (3)
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: CME v8 - Help (?) Button on Phone support
Hi Ryan,
Sorry man ...still not supported
This doc contains all the CME 8.0 (IOS 15.x ) updated info;
url  (telephony-service)
To provision uniform resource locators (URLs) for Cisco  Unified IP phones connected to the Cisco Unified CME router, use the url  command in telephony-service configuration mode. To remove a URL  association, use the no form of this command.
url {authentication |  directories | information | messages | proxy-server | services} url
no url  {authentication | directories | information | messages | proxy-server |  services}
information
Uses  the information at the specified URL for the Information button  display. This button may be labeled "i" or "?".
Note Cisco Unified CME does not support provisioning an  information URL to access help using the i or ? buttons on a phone.
From this  good doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_u1ht.html
Hope this  helps!
Rob
Hi Ryan,
information
From this  good doc;
Hope this  helps!
Rob
Community Member
Thanks Rob!
Community Member
Not quite true. IThe Information URL is supported but the format must be a text file ending with .txt. Ends up to be only a very simple file - not much use. Here's a simple text file that I've used to demonstrate:
http://www.telecomworld.ca/CME-InfoURL.txt
778
