08-07-2012 12:48 PM - edited 03-16-2019 12:35 PM
Hello friends,
I have one Cisco 2811, version IOS 12.4(15)X. I wrote: "show telephony service all", "show version" and "show ccm-manager", but 2811 didn´t show version CME.
How can i know version CME throught CLI command or another form?
Thanks for you help...
08-07-2012 02:08 PM
You need IOS with voice support to configure CME. Then, you can issue show commands.
08-08-2012 06:11 AM
I understand Paolo, but how can i get version CME in 2811 router?
What can i do?
08-08-2012 08:10 AM
Hi Claudio,
The command is :
show telephony-service all
You are missing the hyphen between "telephony" and "service".
Also there are two things that should be done before the above command shows you the :
1.) As Paolo pointed out, the IOS should support voice. Paste the show version output.
2.) configure "telephony-service" first on the router. This will bring up the virtual DSP on the router. Optionally you can configure max-dn and max-ephone commands.
Let me know if this helps.
Arun Kumar
Please rate useful posts.
08-08-2012 09:51 AM
Arun.
I pasted you output... I don´t know why... Any idea please?
CME-IMDEX>
CME-IMDEX>show telephony-service
% Invalid input detected at '^' marker.
CME-IMDEX>show telephony-service all
CME-IMDEX>show run
CME-IMDEX>show version
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(15)X
Z, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 11-Apr-08 17:50 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
CME-IMDEX uptime is 3 weeks, 5 days, 1 hour, 2 minutes
System restarted at 16:08:52 gmt Sat May 12 2012
System image file is "flash:c2800nm-advipservicesk9-mz.124-15.XZ.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 2811 (revision 53.50) with 239616K/22528K bytes of memory.
Processor board ID FTX1218A1EW
2 FastEthernet interfaces
31 Serial interfaces
1 terminal line
1 Channelized E1/PRI port
1 Virtual Private Network (VPN) Module
1 cisco Integrated Service Engine(s)
Cisco Unity Express 3.1.1 in slot 1
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
08-08-2012 02:08 PM
You need to do 'enable' first, and input the corresponding password.
Note: please refrain from half-scale rating posts that are 100% correct, and made with the will to help.
08-08-2012 02:31 PM
Then i should put privilege mode first Paolo?
08-08-2012 02:33 PM
Enable == privileged.
08-08-2012 02:38 PM
Thankyou very much Paolo and Arun....
