CME version 2811 CLI
Hello friends,
I have one Cisco 2811, version IOS 12.4(15)X. I wrote: "show telephony service all", "show version" and "show ccm-manager", but 2811 didn´t show version CME.
How can i know version CME throught CLI command or another form?
Thanks for you help...
Everyone's tags (4)
Hall of Fame Super Gold
You need IOS with voice support to configure CME. Then, you can issue show commands.
I understand Paolo, but how can i get version CME in 2811 router?
What can i do?
Hi Claudio,
The command is :
show telephony-service all
You are missing the hyphen between "telephony" and "service".
Also there are two things that should be done before the above command shows you the :
1.) As Paolo pointed out, the IOS should support voice. Paste the show version output.
2.) configure "telephony-service" first on the router. This will bring up the virtual DSP on the router. Optionally you can configure max-dn and max-ephone commands.
Let me know if this helps.
Arun Kumar
Please rate useful posts.
Arun.
I pasted you output... I don´t know why...   Any idea please?
CME-IMDEX>
CME-IMDEX>show telephony-service
% Invalid input detected at '^' marker.
CME-IMDEX>show telephony-service all
CME-IMDEX>show run
CME-IMDEX>show version
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M),  Version 12.4(15)X
Z, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 11-Apr-08 17:50 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE  (fc1)
CME-IMDEX uptime is 3 weeks, 5 days, 1 hour, 2  minutes
System restarted at 16:08:52 gmt Sat May 12  2012
System image file is  "flash:c2800nm-advipservicesk9-mz.124-15.XZ.bin"
This product contains cryptographic features and is subject to  United
States and local country laws governing import, export, transfer  and
use. Delivery of Cisco cryptographic products does not  imply
third-party authority to import, export, distribute or use  encryption.
Importers, exporters, distributors and users are responsible  for
compliance with U.S. and local country laws. By using this product  you
agree to comply with applicable laws and regulations. If you are  unable
to comply with U.S. and local laws, return this product  immediately.
A summary of U.S. laws governing Cisco cryptographic products may be  found at:
If you require further assistance please contact us by sending email  to
export@cisco.com.
Cisco 2811 (revision 53.50) with 239616K/22528K bytes of  memory.
Processor board ID FTX1218A1EW
2 FastEthernet interfaces
31 Serial interfaces
1 terminal line
1 Channelized E1/PRI port
1 Virtual Private Network (VPN) Module
1 cisco Integrated Service Engine(s)
  Cisco Unity Express 3.1.1 in slot 1
DRAM configuration is 64 bits wide with parity  enabled.
239K bytes of non-volatile configuration  memory.
125440K bytes of ATA CompactFlash (Read/Write)
Re: CME version 2811 CLI
You need to do 'enable' first, and input the corresponding password.
Note: please refrain from half-scale rating posts that are 100% correct, and made with the will to help.
Then i should put privilege mode first Paolo?
Enable == privileged.
Thankyou very much Paolo and Arun....
3179
