CME version 7.0.1 PROBLEM WITH THE DIAL TONE
We have one CME version 7.0.1 connected with the PSTN network with two different connections
One with PRI and the other with analogue lines
We dial 9 for the PRI and 8 for the analogue lines
WITH THE  PRI
Now the issue is that when we dial 9 we have to wait for  dialtone and then dial the number otherwise if we dial 9 and immediately dial the number then we cant establish the call.
WITH THE ANALOGUE LINES
When we dial 8 and the number immediately then everyhting its ok and we dont have to wait for dial tone
Could you pls advice?
below is the telephony service config
telephony-service
sdspfarm units 3
sdspfarm transcode sessions 10
sdspfarm tag 1 conference
sdspfarm tag 2 transcoding
conference hardware
video
em logout 0:0 0:0 0:0
max-ephones 48
max-dn 100
ip source-address 10.8.1.241 port 2000
service phone videoCapability 1
timeouts interdigit 3
timeouts ringing 15
system message Logicom
load 7914 S00104000100
load 7915-12 B015-1-0-2.SBN
load 7915-24 B015-1-0-2.SBN
load 7910 P00405000700
load 7912 P00403020209
load 7921 CP7921G-1.0.3.LOADS
load 7925 CP7925G-1.3.3.LOADS
load 7931 SCCP31.8-1-1SR2S
load 7937 apps37sccp.1-1-1-1
load 7960-7940 P00308010100
load 7961 TERM61.DEFAULT
load 7962 term62.default.loads
load 7965 term65.default.loads
load 7970 term70.default
load 7975 term75.default.loads
load 7985 cmterm_7985.4-1-7-0.bin
time-zone 30
time-format 24
date-format dd-mm-yy
  max-conferences 4 gain -6
moh music-on-hold.au
multicast moh 239.0.0.1 port 2123
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 9T
secondary-dialtone 9
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Green
Can you show the dial peers that make the calls to the PRI
It may be that you need to remove the command secondary-dialtone 9
telephony-service
no secondary-dialtone 9
But it depends on the dial peers
Alex
Regards, Alex. Please rate useful posts.
Hi thank you for the reply
Below is the dial peers for the PRI and for the analogue lines
dial-peer voice 3 pots
description **TO PRI**
preference 1
destination-pattern 9T
progress_ind alert enable 8
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 5 pots
preference 3
destination-pattern 8T
direct-inward-dial
port 0/1/0
dial-peer voice 6 pots
preference 4
direct-inward-dial
port 0/1/1
dial-peer voice 7 pots
preference 5
direct-inward-dial
port 0/1/2
dial-peer voice 8 pots
preference 6
direct-inward-dial
port 0/1/3
dial-peer voice 16 pots
preference 7
direct-inward-dial
port 0/3/3
dial-peer voice 9 pots
preference 8
direct-inward-dial
port 0/2/0
dial-peer voice 10 pots
preference 9
direct-inward-dial
port 0/2/1
dial-peer voice 11 pots
preference 10
direct-inward-dial
port 0/2/2
dial-peer voice 12 pots
direct-inward-dial
port 0/2/3
dial-peer voice 13 pots
direct-inward-dial
port 0/3/0
dial-peer voice 14 pots
direct-inward-dial
port 0/3/1
dial-peer voice 15 pots
direct-inward-dial
port 0/3/2
Green
That looks good then
this peer already has the 9T in it
preference 1
direct-inward-dial
port 0/0/0:15
So can you try testing with
conf t
telephony-service
If you need to put it back the
conf t
telephony-service
Alex
I tried it with out any change
The problem exist and also another one problem that i forgot to mentioned it
When we dial 9 and wait the dial tone and then dial the number , finally the called number is not show on the phone screen
Maybe is a bug of the current cme version?
c2800nm-advipservicesk9-mz.124-22.T5.bin
Bronze
Hi mate,
Could you show configuraton for "inter serial 0/0/0:15" and "debug isdn q931" for calls to PRI when you wait for dialtone?
Also, did you try increasing the interdigit timeout to, say, 10 seconds?
telephony-service
timeouts interdigit 10
Boris
_____ Please rate helpful posts Пожалуйста оценивайте полезные сообщения
Hi mate
interface Serial0/0/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn switch-type primary-net5
isdn timer T310 60000
isdn incoming-voice voice
isdn sending-complete
no cdp enable
end
with the  increasing timeouts interdigit  to 10 then i think we will wait much more when the CME send the call to the ISP or not?
Can someone help with this?
Green
What happens if you remove the secondary dialtone
telephony-service
Make a call with the start 9.XXXXX
Does this call work ?
Alex
637
