CME Version 7.0
Just implemented CME Version 7.0 with only 20 ppl in the company, so didn't go for CCM. Wanted some features that CCM have like:
1) lock the phone with username and password etc, so when users want to use the phone, need to login etc
2) CDR support in CMEv7.0. Can CMEv7.0 send/export the CDR to external apps like excel etc? Any doc will be helpful!!
1 REPLY
Hall of Fame Super Red
Re: CME Version 7.0
Hi Tom,
For the Login feature you may want to use Extension Mobility;
Cisco Unified Communications Manager Express System Administrator Guide
Configuring Extension Mobility
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemobl.html
Here is where the CDR logs are for CME;
show call history voice - Displays the call history table for voice calls.
To specify call detail record (CDR) storage time, use the dial-control-mib command, which has two sets of keyword and argument options. The max-size number option specifies the maximum size of the CDR event table. The valid range is from 0-500, and the default is 50. Setting the value to 0 disables the CDR feature.
The retain-timer number option specifies the length of time in minutes that entries will remain in the call history table. The valid range is from 0-2147483647 minutes, and the default is 15. Setting the value to 0 prevents any call history from being retained.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/srnd/design/guide/managcme.html
Call Activity Monitoring and Call History Logging
The Cisco Unified CME GUI provides call history table information so that a network administrator can monitor the call history information for unknown callers and use this information to disallow calling activities based on select calling patterns. The call history log should be configured to perform forensics and accounting and allow the administrator to track down fraudulent calling patterns. Configure the following commands to log call activity and call history:
dial-control-mib retain-timer 10080
dial-control-mib max-size 500
Logging CDR to External Servers
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/srnd/design/guide/managcme.html#wp1076118
The parsing of this info is the tough part :( You might want to look into Cisco Partner "Stonevoice" that has a nice application for doing up these reports/graphs etc;
http://www.stonevoice.com/Products/AccountingBilling/tabid/767/Default.aspx#o
Hope this helps!
Rob
491
