CME Version 8.6 and cisco jabber
lgrusila avain
We have a cme version 8.6 and we are wondering if we can configure a cisco jabber into our mobile phones
We have android platforms and iphone
Thank you
3 Accepted Solutions
Sure you can.
You have to define it as registrer pool.
Here you have an example.
voice register dn  1
number 2000
name Carlo-Jabber 2000
voice register pool  1
registration-timer max 720 min 660
id mac 1234.5678.0987
session-transport tcp
type Jabber-Android
number 1 dn 1
username carlo password cisco
codec g711ulaw
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
islam.kamal
Level 10
Level 10
In addition to the professional configuration of Mr/Carlo , Please also find the below document which shows you that V8.6 support jabber + required configuration.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmelabel.html#wp1058022
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmelabel.html#wp1063949
Thank you
Please rate all useful information
Hi.
Iphone is the only mobile phone supported by UC5XX because of the release of CME they run.
https://supportforums.cisco.com/docs/DOC-9827
CiscoMobile-iOS is the right device type
Carlo
11 Replies 11
Sure you can.
voice register dn  1
number 2000
type Jabber-Android
number 1 dn 1
codec g711ulaw
Carlo
islam.kamal
Level 10
Level 10
Thank you
Carlo and Islam
Thank you so much
What about UC540 .Its the same philosophy as the above right?
What about if in the type : the cisco jabber is not available and is available only the CiscoMobile-iOS
We have to upgrade the ios  right?
Hi.
Carlo
Carlo
so the only option into UC540 is for iphone only?
Hi.
For the roadmap I posted above, it seems so
Carlo
Ok clear
From the config i dont see also any other device type for example sip device type for any other sip application
So assume that is not supported also any other sip application
For above configuration of type Jabber-Android.  Here we specify the sip client type. It can either be CiscoMobile-iOS for Apple iPhone users or Jabber-Android for Android users
Thank you
iSLAM
Is available only the CiscoMobile-iOS for our device so for android is not any option
That is clear
What i am wondering if we could use other application than jabber with sip profile configuration
but as i see is not any option for sip device except teh default for jabber (either iphone or android)
ohhh , so under type there is no jabber-android. How can if you use CME v8.6 , this will not work if you assign sip application , should mention on type jabber-android.you can try , and i will search for you about files for jabber should be on your flash , to enable jabber-android.
Thank you
Please rate all useful infromation
I think jabber-android only availble on V9 , but i will search about v8.6
Thank you
