CME & VG224
I'm having hard time making the vgg224 work properly on the CME. Able to get calls through the vg224 but not able to make calls. In other words outgoing calls don't seem working.
Here is some of the running configs taken from both devices that might help you specify the problem:
VG224:
interface FastEthernet0/0
ip address 10.1.30.30 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip http server
control-plane
voice-port 2/0
ren 3
disconnect-ack
loss-plan plan4
disc_pi_off
input gain 10
output attenuation 10
playout-delay minimum low
timing digit 53
description cflow1
music-threshold -50
bearer-cap Speech
station-id name GTS
station-id number 262
caller-id enable
ccm-manager config server 10.1.30.100
ccm-manager config
ccm-manager sccp local FastEthernet0/0
ccm-manager sccp
sccp ccm 10.1.30.100 identifier 1
sccp
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 1 priority 1
dial-peer voice 1 pots
service stcapp
port 2/0
forward-digits all
CME:
voice-card 0
dspfarm
voice service pots
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
sip
registrar server expires max 3600 min 3600
voice class codec 1
codec preference 1 g711alaw
Hopefully this will be clear to address the problem.
Re: CME & VG224
I have seen issues with IOS version on vg224 on SCCP configurations. What version of IOS are you running on the VG224 I would recommend 12.4.11XW
Re: CME & VG224
Well we have the 12.4.6XE1, but let me explain something i discovered recently.
The outgoing calls are working fine when i set up the analog phone to a pulse phone. The tone phone setup doesn't work.
Is this a common problem?
Re: CME & VG224
I haven't see that problem.
469
