CME with IPv6 configuration
Hi everyone,
Could anybody in here post a working CME configuration for VoIPv6 only? I was just wondering what are the commands that would replace commands to point to TFTP server like 'option 150 ip xxxx.xxxx.xxxx' and other new commands under DCHP or even Telephony-Service. Just a working config would do. Thanks.
Hello Aditya,
We already have some documents available on Cisco Support Community:
https://supportforums.cisco.com/docs/DOC-13453
Enabling IPv6:
ipv6 unicast-routing
DHCP CONFIGURATION:
ipv6 dhcp pool NEW
address prefix FEC0:0:0:1::/64
link-address FE80::/10
link-address FE80::1AEF:63FF:FE62:BA00/10
Interface Configuration:
interface GigabitEthernet0/0
ipv6 address FEC0:0:0:1::/64 eui-64
ipv6 enable
ipv6 dhcp server NEW
CME configuration:
telephony-service
protocol mode ipv6
ip source-address FEC0::1:1AEF:63FF:FE62:BA00 port 2000
Switch Configuration:
IOS: c3750-ipbasek9-mz.122-55.SE.bin
Platform:  cisco WS-C3750G-48PS
Enabling IPv6:
Vlan Configuration:
interface Vlan10
ipv6 nd autoconfig prefix
ipv6 nd prefix FEC0:0:0:1::/64
Swicth-Port configuration:
interface GigabitEthernet1/0/9
switchport access vlan 10
switchport mode access
and
http://docwiki.cisco.com/wiki/Registering_Cisco_IP_phones_with_CME_8.x_using_IPv6
I hope you will find them useful.
Amit Singh
Hi Amit
I would like you to check the other post of mine. Could you please help me with this VoIPv6 configuration? Thanks.
https://supportforums.cisco.com/message/4169270#4169270
Hello Aditya,
Sure, let me check.
Did the above answer helped in your CME configuration ?
Also, if you configure the setup for IPV4, are the Phones getting an IP address and getting registered, just to isolate any other issues ?
Amit Singh
Hi Amit
I have tried the following link which you have given but its not working (not getting IPv6 address). However, it does work with IPv4 and its getting an IPv4 address. Thanks.
Hi Aditya,
Here is a doc for your reference:
https://supportforums.cisco.com/docs/DOC-13591
*Updated* How to implement the IPv4 & IPv6 dual stack mode on CME 8.0 ?
VERSION 7
Introduction
This  document covers how to implement the IPv4 & IPv6 dual stack mode on  CME 8.0. This will help you if you have multiple partners connected  across ipv6 & ipv4 network and you can Make, Receive calls to your  network using any of the IP. This covers the configuration part on the  CME to enable dual stack mode.
Configuring Ipv4 & Ipv6 on CME 8.0
CME Image on 2811 Router
hostname 2811-ROUTER
boot-start-marker
boot system flash c2800nm-ipvoicek9-mz.150-1.XA1.bin
boot-end-marker
Configure the ipv6 & ipv4 dhcp pool for the IP Phones:
Configure both the ipv6 & ivp6 on the Interface configuration
interface FastEthernet0/1
description #### Internal Interface ####
ip address 124.7.115.85 255.255.255.248
duplex full
speed 100
ipv6 address 3001:E50:0:15::1/64
ipv6 enable
ipv6 dhcp server Call-manager
Telephony-service configuration for CME
# voice service voip
sip
bind control source-interface FastEthernet0/1
sccp ccm group 1
associate ccm 1 priority 1
protocol mode dual-stack preference ipv6
max-ephones 42
max-dn 144
ip source-address 124.7.115.85 port 2000
ip source-address 3001:E50:0:15::1
service phone settingsAccess 1
system message CCME 8.0
cnf-file location flash:
cnf-file perphone
load 7911 SCCP11.8-3-3SR2S
load 7970 SCCP70.9-0-2SR1S
max-conferences 16 gain -6
moh music-on-hold.au
dn-webedit
time-webedit
transfer-system full-consult secondary-dialtone 9
create cnf-files version-stamp Jan 01 2010 00:00:00
Note:-  CME with dual-stack Mode and IPV6 preference. This "dual-stack mode"  will enable CME to work on both ipv6&ipv4 and you can set any IP  version as preference.
Note:- Both ipv4 & ipv6 source address configured for communication
Configure ephone & ephone-dn
ephone-dn 1
number 1003
name testlab-1
ephone 1
nte-end-digit-delay 100
keypad-normalize
mac-address 0014.789C.3C0E
type 7970
button 1:1
Rate the post accordingly.
Kevin
Hi Kevin
Thanks buddy. Will give a try. But before let me ask you and remind that I am using SCCP but the below configuration mentions sip. Will this make any difference? Thanks
sip
sccp ccm group 1
max-ephones 42
max-dn 144
cnf-file perphone
dn-webedit
time-webedit
Hi Aditya,
It does specify configuration for Skinny too:
ephone-dn 1
number 1003
name testlab-1
ephone 1
keypad-normalize
type 7970
button 1:1
Kevin
Hi Kevin
Thanks for the prompt reply. I will try and test this soon and let you know. Thanks.
352
