cme with isdn
i am trying to connect isdn.but i couldnt assign timeslots.
cme(config-controller)#pri-group timeslots 1-31
%ISDN Error: Maximum allowed PRI interfaces exceeded.
what could be the reason?
thanks
kavi
Everyone's tags (2)
VIP Super Bronze
cme with isdn
What type of gateway do you have? Looks like you are exceeding the allowable interfaces for the router. Can you send a sh version and a sh run
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
cme with isdn
cme#show ver
cme#show version
Cisco IOS Software, C1861 Software (C1861-ADVENTERPRISEK9-M), Version 15.2(3)T,        RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Fri 23-Mar-12 15:23 by prod_rel_team
ROM: System Bootstrap, Version 12.4(11r)XW3, RELEASE SOFTWARE (fc1)
cme uptime is 1 day, 23 hours, 14 minutes
System restarted at 11:16:42 pssss Thu Aug 23 2012
System image file is "flash:c1861-adventerprisek9-mz.152-3.T.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C1861E-UC-4FXO-K9 (MPC8358) processor (revision 0x300) with 497664K/26624K bytes of memory.
Processor board ID FGL161221C8
MPC8358 CPU Rev: Part Number 0x804A, Revision ID 0x21
12 User Licenses
10 FastEthernet interfaces
2 terminal lines
1 Channelized E1/PRI port
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
1 cisco service engine(s)
128K bytes of non-volatile configuration memory.
126976K bytes of ATA CompactFlash (Read/Write).
cme#show diag
Slot 0:
        C1861 Mainboard 1FE, 8FE POE, Stacking FE, MOH, Port adapter
        Port adapter is analyzed
        Port adapter insertion time unknown
        Hardware Crypto Engine Details:
          The CHIP id is 0x10003
          The SEC revision no is 0x1
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC15510MGN
        Hardware Revision        : 3.0
        Top Assy. Part Number    : 800-35810-01
        Board Revision           : D0
        Deviation Number         : 0
        RMA Test History         : 03
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : B2
        Hardware date code       : 0
        Chassis Serial Number    : FGL161221C8
        Chassis MAC Address      : 649e.f34e.3d40
        MAC Address block size   : 32
        CLEI Code                : CMMDG00ARA
        Product (FRU) Number     : C1861E-UC-4FXO-K9
        Part Number              : 73-13881-01
        Version Identifier       : V01
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 35 35 31 30 4D 47 4E 40
          0x10: 05 60 41 03 00 C0 46 03 20 00 8B E2 01 42 44 30
          0x20: 88 00 00 00 00 03 03 03 00 81 00 00 00 00 04 00
          0x30: 09 B2 83 00 00 00 00 C2 8B 46 47 4C 31 36 31 32
          0x40: 32 31 43 38 C3 06 64 9E F3 4E 3D 40 43 00 20 C6
          0x50: 8A 43 4D 4D 44 47 30 30 41 52 41 CB 92 43 31 38
          0x60: 36 31 45 2D 55 43 2D 34 46 58 4F 2D 4B 39 20 82
          0x70: 49 36 39 01 89 56 30 31 00 D9 04 40 C1 C2 CB FF
        FXO Voice IO Card:
        Hardware Revision        : 4.0
        PCB Serial Number        : FOC16104E6H
        Part Number              : 73-10820-04
        Board Revision           : C0
        RMA History              : 00
        Product (FRU) Number     : VOICE IO CARD
        Top Assy. Part Number    : 800-28035-03
        CLEI Code                :
        Version Identifier       : V02
          0x00: 04 FF 40 05 61 41 04 00 C1 8B 46 4F 43 31 36 31
          0x10: 30 34 45 36 48 82 49 2A 44 04 42 43 30 03 00 81
          0x20: 00 00 00 00 04 00 88 00 00 00 00 CB 8D 56 4F 49
          0x30: 43 45 20 49 4F 20 43 41 52 44 C0 46 03 20 00 6D
          0x40: 83 03 C6 8A 20 20 20 20 20 20 20 20 20 20 89 56
          0x50: 30 32 20 FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        PVDM Slot 0:
        32-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
        Part Number              : 73-8539-05
        Board Revision           : C0
        Fab Version              : 04
        PCB Serial Number        : FOC15473L2E
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM2-32
          0x00: 04 FF 40 03 EE 41 04 00 82 49 21 5B 05 42 43 30
          0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 35 34 37
          0x20: 33 4C 32 45 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 88 50 56 44 4D 32 2D 33 32 89 56 30 31 20 D9 02
          0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        VIC Slot 0:
        3rd generation - FXS DID Voice daughter card (4 port)
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-27473-03
        Board Revision           : C0
        Fab Version              : 01
        PCB Serial Number        :
        RMA History              : 00
        Product (FRU) Number     : VIC3-4FXS/DID
        CLEI Code                : TBD
        Longitudinal Calibration : 01 10 10 5F 7C 10 10 41
                                   BE 10 10 98 5B 10 10 85
                                   9A
          0x00: 04 FF 40 05 1B 41 01 00 C0 46 03 20 00 6B 51 03
          0x10: 42 43 30 88 00 00 00 00 02 01 C1 8B 20 20 20 20
          0x20: 20 20 20 20 20 20 20 03 00 81 00 00 00 00 04 00
          0x30: CB 8D 56 49 43 33 2D 34 46 58 53 2F 44 49 44 89
          0x40: 56 30 31 20 D9 02 40 C1 C6 8A 54 42 44 20 20 20
          0x50: 20 20 20 20 D3 11 01 10 10 5F 7C 10 10 41 BE 10
          0x60: 10 98 5B 10 10 85 9A FF FF FF FF FF FF FF FF FF
        VIC Slot 1:
        2nd generation - FXO Voice daughter card (4 port)
        Hardware Revision        : 5.0
        Top Assy. Part Number    : 800-21589-04
        Board Revision           : C0
        Deviation Number         : 0-0
        Fab Version              : 04
        PCB Serial Number        :
        RMA History              : 00
        Product (FRU) Number     : VIC2-4FXO
        Version Identifier       : V03
        CLEI Code                : CNUIAPRAAA
          0x00: 04 FF 40 00 4C 41 05 00 C0 46 03 20 00 54 55 04
          0x10: 42 43 30 80 00 00 00 00 02 04 C1 8B 20 20 20 20
          0x30: CB 89 56 49 43 32 2D 34 46 58 4F 89 56 30 33 20
          0x40: C6 8A 43 4E 55 49 41 50 52 41 41 41 FF FF FF FF
        HWIC Slot 2:
        VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1
        Hardware Revision        : 0.0
        Top Assy. Part Number    : 800-22628-05
        Board Revision           : E0
        Fab Version              : 04
        PCB Serial Number        : FOC152631U5
        RMA History              : 00
        Product (FRU) Number     : VWIC2-1MFT-T1/E1
          0x00: 04 FF 40 03 FD 41 00 00 C0 46 03 20 00 58 64 05
          0x10: 42 45 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 35 32 36 33 31 55 35 03 00 81 00 00 00 00 04 00
          0x30: CB 90 56 57 49 43 32 2D 31 4D 46 54 2D 54 31 2F
          0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
        VIC Slot 4:
        One port MOH Voice Interface
        Built-in 9 ports Ethernet Switch with ILP Support for 8 ports
        Hardware: Marvell 88E6083 Chip   Revision: 1
        LTC4258 PoE controller#0:
        IC version: 0x4 Firmware revision: 0x0 Silicon revision: 0x0
        LTC4258 PoE controller#1:
        Onboard Service Engine: 0
i already configured the isdn before.and then i configured  meetme conference.so it took some dsp resourses.after that i tried to configure isdn but i couldnt its because of not enough dsp.then i removed meetme conference.then can able to configure isdn.but now also the same i couldnt configure the isdn.i think its because of not enough dsp resource. icouldnt find out what other featues  consume dsp.
cme with isdn
cme#show dspfarm dsp all
Total number of DSPFARM DSP channel(s) 0
there is no dsp channel here.but this cme has PVDM.
        PVDM Slot 0:
        Board Revision           : C0
        Fab Version              : 04
        RMA History              : 00
        Processor type           : 00
cme with isdn
Can you show us
show inventory result
I think you dont have enoguh pvdm.
try giving following command.
pri-group timeslots 1-10,16
instaed of
Please rate if helpful.
cme with isdn
cme#show inventory
NAME: "C1861E-UC-4FXO-K9 Chassis", DESCR: "C1861E-UC-4FXO-K9 Chassis"
PID: C1861E-UC-4FXO-K9 , VID: V01, SN: FGL161221C8
NAME: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 in DaughterCard Slot 2", DESCR: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-1MFT-T1/E1  , VID: V01 , SN: FOC152631U5
i already tried pri-group timeslots 1-10,16.but still the same result.  "%ISDN Error: Maximum allowed PRI interfaces exceeded."
thanks
623
