CME with Linksys PAP2T
phoenix3195
I have a problem with Linksys PAP2T ATA:
I have call manager express on cisco 2811 (version 7.01) and I configured ephones and ephone-dn as the followings:
ephone  2
device-security-mode none
mac-address A0BB.6D41.2C01
max-calls-per-button 4
username "all"
type 7925
button  1:2
ephone  3
mac-address 0026.AB22.F5F2
button  1:3
ephone-dn  2
number 5802
label 5802
ephone-dn  3
number 5803
label 5803
and here is the voice register configuration:
voice service voip
allow-connections h323 to sip
allow-connections sip to sip
sip
  bind control source-interface FastEthernet0/0.1
  bind media source-interface FastEthernet0/0.1
  registrar server
voice register global
mode cme
source-address 192.168.19.1 port 5060
max-dn 2
max-pool 2
create profile sync 009508401118860A
voice register dn  1
number 5804
voice register dn  2
number 5805
voice register pool  1
id mac 0023.69AB.0292
number 1 dn 1
number 2 dn 2
username 5804 password 5804
The calls between the cisco phones are working fine, calls from cisco phones to the analog phones connected to linksys ATA is working, but I am unable to call from the ATA to cisco phones. I tried changing codecs and it did not work. I attached debug output (debug ccsip messges).
Any ideas?
Thank you
jbollen
It is a bit difficult to come to a conclusion but I would suggest that you compare the posted SIP Debug
with a SIP debug of a succesful call from a Cisco IP phone to the analogue phone connected to the PAP2T.
I suspect that one line in the SDP body sent by the ATA, is not accepted by the router:
a=rtpmap:18 G729a/8000
Not sure, but I suspect that the suffix "a" should not be there. That would be confirmed or denied by a succesful test. It reminds me of the old IOS bug where G729 was sent as G.729 with the "offending" dot.
Else remove all codecs but G711 a- or u-law via the mgmt web page of the PAP2T. It should work.
The Q.850 diagnostic code "65" means "bearer capability not implemented" and it could point to a codec issue.
Hope this helps,
Best regards,
Jan
jbollen
Hope this helps,
Best regards,
Jan
I fixed this issue, you are right it was a codec mismatch issue. I added the following under the voice register pool
codec g711ulaw
Thanx
