CME WITH PSTN to CME without PSTN.
i have 2 sites named A and B
Site A has CME and PSTN.
Site B has CME no PSTN.
What I want is to make CME to CME calls and Site B can call PSTN located @ Site A.
Is it by just pointing to SITE A IP address, I will achieve this?
Re: CME WITH PSTN to CME without PSTN.
dial-peer v 1 voip
destination-pattern 2...$
session-target ipv4:1.1.1.2
Hall of Fame Super Silver
As suggested by Shrvaran you achive this by using dial peers and pointing to the other CME as session target, you will also need to allow sip or h323 protocol via the following configs:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
HTH,
Chris
i want to make use of the PSTN @ Site A from Site B. Site B doesnt have PSTN so if Site B want to make outside call it should route it to Site A CME with PSTN.
please reply ASAP if this is achievable.
Green
As the shrvaran & chris have shown this CAN be acheived. (+5 )
You need IP connectivity between the sites.
You need to create dial peers and allow the service in voip.
You need to know if you want to use H323 or SIP
So at site "B" say dial a 9 for PSTN access
CME-B
dial-peer voice 9 voip
description *** TESTING PSTN H323 DIAL PEER ***
destination-pattern 9T
voice-class codec 1
session target ipv4:172.16.255.11
incoming called-number .
dtmf-relay h245-alphanumeric
ip qos dscp cs3 signaling
no vad
CME-A
voice service voip
Alex
Regards, Alex. Please rate useful posts.
Hello
Having d issue here, SiteB can call SiteA but SiteA cannot call SiteB. I have issued "voice service voip" allow-connectionson both routers.
Please what might cause this?
Check if you have dial peer in Site A pointing to Site B
Hello
I have a dial-peer in Site A pointing to Site B, I use 4digit. When you call from Site A 4digit, when you type in all the 4 digit...I get busy tone. Debug showing its initiating the call but showing "Disconnectcause is 10" .
Please need help ASAP.
Hi ,
If possible ,can you post a  sh run conf for the sites.
SITE A directory and Dial-peer: 1..,208 and 218 ,3..,4..,5xx,6xx,
Dial-peer voice 1001 voip
Destination-pattern 7T
Session protocol sipv2
Session target sip-server
Dial-peer voice 600 voip
Description calls to SiteB
Destination-pattern 2[1-3]..$
Session target ip:1.1.1.10
Incoming called-number .
Dtmf-relay h245-alphanumeric
SITE B directory number and Dialplan
2[1-3]..$
Dial-peer voice 10 voip
Description calls to SiteA
Destination-pattern ..$
Session target ip:192.168.8.1
Dial-peer voice 20 voip
Destination-pattern 1..$
Session target ip:198.168.8.1
Destination-pattern 20.$
Destination-pattern 2[4-9].$
Note; Site B can call site A but not vice versa.
So site A has 3 digit extension's and B has 4 digit..
Is the call from site A reaching the Site B  .Can you see any  q931 logs in B?
hello,
note: Site A have the voice-card connected to the pstn but site B did not have it. site B do connect to site A for pstn access.
site A has 3 digit while site B has 4 digit extension number.
site B can call site A but Site A cannot call back to site B.
we are using FXO/FXS port on site A.
through debug command, calls are showing from site A to Site B but after u dial the last 4 digit you get a busy signal tone.
please, what might have cause this and what debug command shud i turn-on on site B to check maybe calls are hitting site B router?
debug isdn 931 IS NOT WORKING.
HELP
Hi ,
sorry 'debug isdn q931' was not the command.
You can use 'debug voice ccapi inout' to check if the calls are hitting site B.
Also you can check if correct dial-peers are matched during the call flow with 'debug voice dialpeer'.
Thanks to you all. Its working now.
If you could tell what was the issue...just for informartion
Site A is pointing to the SIP server which is
sip-ua
retry register 10
registrar ipv4:209.15.1.1 expires 60
sip-server ipv4:209.15.1.1
dial-peer voice 1001 voip
translation-profile outgoing profile1
destination-pattern 7T
session protocol sipv2
session target sip-server
Dialing to the sip server is working on site A but Site B needs to connect to site A to dial to the sip server.
Note: Site B does not have a public IP so it need to connect to site A.
What and what do I need to config on site B.
Please reply ASAP. Thanks
Its working now.
But there is a problem.
I am pointing to a SIP server from Site A, but now I want users on Site B to point to Site A using the SIP server.
On Site A;
Sip-ua
Retry registrar 10
Registrar ipv4:
Now I want Site B to point to A for SiP connection.
Its working now.
On Site A;
Sip-ua
Retry registrar 10
Registrar ipv4:
Its working now.
On Site A;
Sip-ua
Retry registrar 10
Registrar ipv4:
Its working now.
On Site A;
Sip-ua
Retry registrar 10
Registrar ipv4:
Its working now.
On Site A;
Sip-ua
Retry registrar 10
Registrar ipv4:
Its working now.
On Site A;
Sip-ua
Retry registrar 10
Registrar ipv4:
Its working now.
On Site A;
Sip-ua
Retry registrar 10
Registrar ipv4:
hello
plz is this command going to be in both routers?
voice service voip
allow-connection sip to sip
allow-connection sip to h323
allow-connection h323 to sip
H323
Sip
676
