10-08-2010 06:56 AM - edited 03-16-2019 01:14 AM
I am looking at a CME setup for a multisite site environment. The phones at the remote sites will then connect to the CME router at the main office. I am trying to determine whether or not SRST can be used at the remote offices if the CME router goes down.
Solved! Go to Solution.
10-08-2010 07:13 AM
Pl. take a look at "Redundant Cisco Unified CME Router"
10-08-2010 07:13 AM
10-21-2010 06:16 AM
Thank you for the prompt response, this is what I needed to see!
