CME with tandberg 6000
hi all,
for our branch we have a cisco ISR router 2811running CME wih E1 port   and tandberg 6000 .
my question is : what are  the requirements to make calls between tandberg 6000 and other tandberg  equipement in the HQ using E1 interface ?
thanks for your reply .
Hall of Fame Super Gold
Re: CME with tandberg 6000
You must be able to configure both devices (certification level).
If you are not able to, recommend you hire a reptuable consutlant or certfied cisco partenr for the job, because you will only loose time and gain frustration trying to do it yourself.
thanks for your response .i'm asking for the licences to purchase to support this deployement .
No additional licenses are necessary.
Please remember to rate useful posts clciking on the stars below.
295
