CME wont call-forward to CUE
I cant seem to get CME to call-forward to CUE - or when it does the call just gets disconnected.
Here is my config - pretty much the same as this good example:
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a008037f2a9.shtml#req
Anyone have any ideas?
interface GigabitEthernet0/0
description Private Link Network
ip address 172.19.0.138 255.255.255.248
duplex auto
speed auto
interface Service-Engine0/0
ip unnumbered GigabitEthernet0/0
service-module ip address 172.19.0.139 255.255.255.248
service-module ip default-gateway 172.19.0.137
dial-peer voice 1 voip
mailbox-selection last-redirect-num
destination-pattern 99..
session protocol sipv2
session target ipv4:172.19.0.139
dtmf-relay sip-notify
codec g711alaw
no vad
telephony-service
no auto-reg-ephone
authentication credential otn Ms3rv1c3
em logout 0:0 0:0 0:0
max-ephones 58
max-dn 192 no-reg primary
ip source-address 172.19.0.138 port 2000
url services http://172.19.0.139/voiceview/common/login.do
url authentication http://172.19.0.138/CCMCIP/authenticate.asp
cnf-file location flash:
load 7921 CP7921G-1.2.1.LOADS
load 7942 SCCP42.8-4-2S.loads
load 7962 SCCP42.8-4-2S.loads
load ata ATA030203SCCP051201A.zup
time-zone 47
time-format 24
date-format dd-mm-yy
dialplan-pattern 1 566727.. extension-length 4 extension-pattern 27..
voicemail 9999
max-conferences 8 gain -6
hunt-group logout HLog
web admin system name otn password Ms3rv1c3
dn-webedit
transfer-system full-consult
fac standard
create cnf-files version-stamp 7960 Mar 25 2009 20:44:32
ephone-dn 92
number 2792
label Adam
name Adam
call-forward busy 9999
call-forward noan 9999 timeout 10
ephone-hunt login
ephone 92
description Adam
mac-address 0024.97A9.F649
codec g729r8
type 7942
button 1:92
Re: CME wont call-forward to CUE
Not sure if this is your issue but I have seen issues like this when Cue is not initialised.
Connect to the GUI of the CME module log in and initialise.
In the dial-peer voice 1 voip change that codec to g711ulaw and try.
This is correct - the CUE module only supports G711ulaw. alaw isn't supported on CUE.
-nick
Great - thanks for spotting this error.
I'll try G711ulaw and let you know the result.
Unfortunately changing the codec to G711ulaw didn't seem to help.
CUE is also initialised and I have created a number of mailboxes.
Any further suggestions?
Hall of Fame Super Gold
Take "debug ccsip message" with "term mon" and you will see why CUE is refusing the call.
A few things to check on CME:
-Do you have the 255.255.255.255 route defined statically pointing towards the service engine?
-Can you ping CUE?
-If you have a SIP trunk coming in, you need:
voice service voip
allow sip-to-sip
A few things to check on CUE:
-Under ccn subsystem sip, do you have the correct IP address defined for CME
-Does your sip target match what you're dialing?
-nick
I was using 9999 as the CUE extension. I changed it to 9992 and all now works fine.
Looks like ext9999 is used by a public distribution list for all users.
Thanks for the tips anyway.
Cheers
Kent.
Do you have transcoders configured? If yes, can you make a test call and see them engaging?
thanks.
I had the same thing: I could call the VM pilot (being 9999 in your case), but transfer to 9999 fails. Try to remove the command "dialplan-pattern 1 566727.. extension-length 4 extension-pattern 27.. " under Telephony-service. That fixed my problem.
Greets,
David
271
