Community Member
CME
Hi there !
In CM 4.2 there's a FAC (Forced Authorization Code) for each user that is allowed to place external calls..
Does CME has the same feature ?
Thanks.
Andrei.
Re: CME
Hi Andrei,
You can use Call Blocking Override. Take a look at the admin guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeblock.html#wp1013708
Hope it helps you.
Best regards,
- Adrián.
Re: CME
no, most similar is a script
PLEASE use the SEARCH function in netpro, this has been asked many, many, many times before
IP Telephony: Dial using pin number
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40^1%40%40.2cd235cb/1#selected_message
IP Telephony: CME- How can i make outgoing PSTN calls only with a key like FAC (in cucm)
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc2c634
And there are many other posts on the exact same matter
java
if this helps, please rate
java
www.cisco.com/go/pdi
Anonymous
N/A
Re: CME
Andrei,
Try this;
application
service clid clid_authen_collect
  param uid-len 4
  param pin-len 4
On your dial peers add this command;
service clid_authen_collect
Vikram
240
