Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CME
Hi netpro's
I need to run my configuration past you and ask the following questions:
(I am running CME7 on a 1861 router with 2 built in ISDN BRI's)
1 - When I connect my two BRI interfaces to the ISDN TA it stops me from sending and receiving calls. If I disconnect one of the BRI interfaces it works. Is the problem because I don't have the trunk-group commend configured on my BRI ports??
2 - I have created a voice-translation rule 1 that isn't working. I want all my local users to dial 39xx, 82xx, etc 4 digit extensions which will automatically map to e.164 number for example local user dials 8218 and is automatically put through to 01925 858218
3 - The 2 ISDN BRIs have 10 DDI number - is there any configuration missing that would stop DDI and CLI numbers being sent and recieved from the CME?
Thats all.
Thanks in advance.
Rod
Hall of Fame Super Gold
Re: CME
1. No. Which exact IOS are you running
2 Use bulk list speed-dial for that. explained in admin manual
3 not evidently - may be related to problem .1.
Re: CME
Hi P,
I am not back at site until Monday and will let you know what IOS I am runnig.
I get what you are saying about the bulk speed dial, however is there a way that the user can pick up the phone and just dial the 4 digit extension with CME appending the full e.164 number?
Rod
Re: CME
Well, that is what a bulk speed-dial is for, you can use other means (personal speed-dial, translation rules) but are less scalable and convoluted.
Re: CME
Hi P.
I am still having the same problems at this site. I have 2 isdn bri circuits with 10 DDI numbers - when I enable the isdn static tei 0 on the second bri interface i get an engaged tone when dialing the site - the only way I can fix the problem is by removing the ISDN static tei 0 from my configuration from interface bri0/1/1
below is the output from the Q931 debug.
One more question - what exactly does the isdn static tei 0 do to the interface? and do i need it for the bri interfaces to trunk calls?
Rod
Sep 28 07:20:30.608: ISDN BR0/1/0 Q931: TX -> ALERTING pd = 8 callref = 0x81
Progress Ind i = 0x8188 - In-band info or appropriate now available
Sep 28 07:20:30.608: ISDN BR0/1/1 Q931: TX -> ALERTING pd = 8 callref = 0x81
Sep 28 07:20:30.940: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Sep 28 07:20:31.608: ISDN BR0/1/1 Q931: TX -> ALERTING pd = 8 callref = 0x81
Sep 28 07:20:31.692: ISDN BR0/1/1 **ERROR**: L2_AdvanceVA: TX_ack_queue empty
Sep 28 07:20:32.980: ISDN BR0/1/1 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Sep 28 07:20:35.016: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Sep 28 07:20:37.052: ISDN BR0/1/1 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Sep 28 07:20:39.092: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Re: CME
Hi, as I told you in another message, you are receiving the same message on both interfaces, that is not normal, both circuit and router must be checked.
Re: CME
Hi P.
After more investigation I have found the BT have configured my circuit with 1 physical port with the 4 channels - thats why I was getting the issue of the two interfaces coming up when making or receiving calls.
I have unplugged the cable from int bri0/1/1 and only have bri0/1/0 active. The problem is that I can only have 2 calls active at any time and not the 4 I would expect - do I need to configure my bri port differntly to whats listed below:
interface BRI0/1/0
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
trunk-group BRI
trunk group BRI
translation-profile outgoing DNIS
voice translation-rule 10
rule 1 // /01946/
voice translation-profile DNIS
translate calling 10
Re: CME
As replied in another thread - BRI cannot have 4 channels, you can cross-check any source you want about that.
374
