CME4-Fallback and CCM 5.12
Was looking for the min requirements for implementing CME-fallback on a ISR. Was thinking that I do not need to load any of the CME files (admin, html, phone loads...), just needed the telephony-service configuration. I just want to be able to use the enhanced features during fallback, but not CME itself.
I have looked at the CME4 admin/install guide as well as a Cisco provided CME4-fallback lab config guide and the two definitely do not match up on the requirements.
Thanks.
1 ACCEPTED SOLUTION
Super Bronze
Re: CME4-Fallback and CCM 5.12
You just need the configuration elements... not the GUI files/phone loads etc - last thing you want is phones to change firmware every time it fails to SRST.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
1 REPLY
Super Bronze
Aaron
97
