Community Member
CME7.1 + CUE7.0: Transfer to Voice Mail
the softkey TrnsfVM on IP Phone works if followed by inputting an extension, but if I push the speed dial button instead, I hear error message" there's no mailbox associated with the extension", then the call is transferred back by CUE.
is this normal behavior?
thanks,
Jonathan
Bronze
Re: CME7.1 + CUE7.0: Transfer to Voice Mail
If the call does go to voicemail but the wrong greeting is played--or even one that states that there is no mailbox associated with this number--then the problem is likely that the E.164 number is not assigned to the subscriber.
Community Member
if you input the extension mannually, the call goes thru. Cisco TAC determines this is caused by a bug, will be resolved on 12.4.24T2
173
