CME9.0 : Locale file for 8941 SCCP
Hi all,
I've downloaded local files for CME9.0
But in the tar file, there is no file like
gh-sccp.jar, there is only
gh-sip.jar
And in the debug I see 8941-SCCP requesting file gb-sccp-sip.jar.
Feb  2 07:06:29.598: TFTP: Looking for French_France/gb-sccp-sip.jar
So what is the gb code?
What is the real file for the 8941 SCCP.
Please help.
regards,
Antra
1 ACCEPTED SOLUTION
Found a solution:
  1. download the locale for cme versione 9.1, file cme-full-9-1-locale.rar
  2. extract the file for your language, for me is DE: CME-locale-de_DE-German-8.8.2.5.tar
  3. from the locale language file extract the file gb-sccp-sip.jar
  4. copy the file gb-sccp-sip.jar in your flash0:/its/ directory
  5. add the command in you cme configuration: tftp-server flash0:/its/gb-sccp-sip.jar alias German_Germany/gb-sccp-sip.jar
  6. reset the phone.
Christian
Hall of Fame Super Red
Hi Antra,
Sorry to see you are having issues here
We have not done this as we don't run CME 9.0 but I do see
some "new" references for 9.0 localization in this doc. Maybe it
may help
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmelocal.pdf
Cheers!
Rob
hi,
do you find the correct file to change the language on 8941 SCCP??
Pedro
No success till now.
I've tried the file downloaded with the locale files but, the IP phone doesn't change its layout.
It is still the english language.
regards,
Antra
Same problem Here for the phone 8941, the file doesn't exist.
Christian
Found a solution:
  6. reset the phone.
Christian
I downloaded 9.1 & 9.0 full archives, both don't include the locales.
Hi Steffen,
Try the individual file set from this path
Unified Communications Manager Express Individual File Set-9.0
Cheers!
Rob
"Celebration it's around us, every nations, all around us.
Singin' forever young, singin' songs underneath that sun" - K'naan
Hello ,
How are you doing ? I was searching for this file gb-sccp-sip.jar and I see that you already have this file please can you share it with me. I would like to convert a cp-8941 to sip.
Thank you.
Re: CME9.0 : Locale file for 8941 SCCP
Please refer to the CME guide that Rob posted, particularly the section titled Using the Locale Installer in CME 7.0.1 or later. You need to download the full local tar files for 9.1 located below and extract the file locally on your pc. There are a number of individual tar files for specific localisation, you simply need to upload the tar file to flash, there is no specific requirement to extract the files to flash. Follow the guideline for configuring cnf-files per phone and set user-defined locale:
http://www.cisco.com/cisco/software/release.html?mdfid=277641082&flowid=5337&softwareid=282897001&release=9.1&relind=AVAILABLE&rellifecycle=&reltype=latest
Please rate helpful posts. Thank you.
Allan
Ouff my god ,
     Please no one can help me I have posted my issue and the phone stay still not used.
I have purchased a SmartNet service but I still can not access the server to download them. Please Help me .
VIP Purple
Hi ,
You can write a mail to csgbprod@cisco.com and share your SmartNet Contract along with CCOId to get the access.
regds,
aman
Here's the file that I need to finish with the starting process.
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:07:7D:DF:C0:3A [15/04 12:28:00.171]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:07:7D:DF:C0:3A [15/04 12:28:00.187]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:07:7D:DF:C0:3A [15/04 12:28:04.171]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:07:7D:DF:C0:3A [15/04 12:28:04.187]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:07:7D:DF:C0:3A [15/04 12:28:12.171]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:07:7D:DF:C0:3A [15/04 12:28:12.187]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:07:7D:DF:C0:3A [15/04 12:28:28.171]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:07:7D:DF:C0:3A [15/04 12:28:28.187]
Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac 00:07:7D:DF:C0:3A [15/04 12:29:00.265]
Client requested address 0.0.0.76 [15/04 12:29:00.265]
DHCP: proposed address 192.168.0.105 [15/04 12:29:02.484]
Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac 00:07:7D:DF:C0:3A [15/04 12:29:02.500]
Client requested address 0.0.0.76 [15/04 12:29:02.500]
DHCP: proposed address 192.168.0.105 [15/04 12:29:04.484]
Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac 00:07:7D:DF:C0:3A [15/04 12:29:04.500]
Client requested address 0.0.0.76 [15/04 12:29:04.500]
DHCP: proposed address 192.168.0.105 [15/04 12:29:06.484]
472 Request 2 not processed [15/04 12:29:06.500]
472 Request 2 not processed [15/04 12:29:06.515]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:07:7D:DF:C0:3A [15/04 12:29:06.515]
Previously allocated address 192.168.0.105 acked [15/04 12:29:06.515]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:07:7D:DF:C0:3A [15/04 12:29:06.531]
Previously allocated address 192.168.0.105 acked [15/04 12:29:06.531]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:07:7D:DF:C0:3A [15/04 12:29:06.546]
Previously allocated address 192.168.0.105 acked [15/04 12:29:06.546]
472 Request 2 not processed [15/04 12:29:06.562]
472 Request 2 not processed [15/04 12:29:06.578]
472 Request 2 not processed [15/04 12:29:06.593]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:07:7D:DF:C0:3A [15/04 12:29:06.593]
Previously allocated address 192.168.0.105 acked [15/04 12:29:06.593]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:07:7D:DF:C0:3A [15/04 12:29:06.609]
Previously allocated address 192.168.0.105 acked [15/04 12:29:06.609]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:07:7D:DF:C0:3A [15/04 12:29:06.625]
Previously allocated address 192.168.0.105 acked [15/04 12:29:06.625]
472 Request 2 not processed [15/04 12:29:06.640]
472 Request 2 not processed [15/04 12:29:06.656]
472 Request 2 not processed [15/04 12:29:06.671]
472 Request 2 not processed [15/04 12:29:06.687]
472 Request 2 not processed [15/04 12:29:06.703]
472 Request 2 not processed [15/04 12:29:06.718]
472 Request 2 not processed [15/04 12:29:06.734]
472 Request 2 not processed [15/04 12:29:06.750]
472 Request 2 not processed [15/04 12:29:06.765]
472 Request 2 not processed [15/04 12:29:06.781]
Connection received from 192.168.0.105 on port 56835 [15/04 12:29:08.656]
Read request for file . Mode octet [15/04 12:29:08.656]
File : error 2 in system call CreateFile The system cannot find the file specified. [15/04 12:29:08.656]
Connection received from 192.168.0.105 on port 54592 [15/04 12:29:08.687]
Read request for file . Mode octet [15/04 12:29:08.687]
Using local port 1039 [15/04 12:29:08.687]
: sent 11 blks, 5365 bytes in 0 s. 0 blk resent [15/04 12:29:08.703]
Connection received from 192.168.0.105 on port 39464 [15/04 12:29:12.890]
Read request for file . Mode octet [15/04 12:29:12.890]
File : error 2 in system call CreateFile The system cannot find the file specified. [15/04 12:29:12.890]
Connection received from 192.168.0.105 on port 42277 [15/04 12:29:12.921]
Read request for file . Mode octet [15/04 12:29:12.921]
Using local port 1041 [15/04 12:29:12.921]
: sent 11 blks, 5365 bytes in 0 s. 0 blk resent [15/04 12:29:12.937]
Connection received from 192.168.0.105 on port 55972 [15/04 12:29:15.843]
Read request for file . Mode octet [15/04 12:29:15.843]
File <\gb-sccp-sip.jar> : error 2 in system call CreateFile The system cannot find the file specified. [15/04 12:29:15.843]
1988
