CMM image
Native 6509 with CMM voice module. When upgrade IOS in the supervisor module, does the CMM module auto upgraded, is there a seperate module image for CMM that we apply seperately if need to upgrade CMM for some bug? Thanks
Hall of Fame Super Red
Re: CMM image
Hi CF,
CMM has its own software image; the image is not bundled with the supervisor engine or MSFC images.
Software Upgrade Procedure
From this doc;
Release Notes for the Cisco Catalyst 6500 Series and the Cisco 7600 Series Communication Media Module for Cisco IOS Release 12.3(8)XY
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/relnotes/ol_6314.htm#wp156843http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/relnotes/ol_6314.htm#wp156843
Hope this helps!
Rob
Re: CMM image
Thanks very much. So in order to configure CMM, we have to use session command going to the module and configure it as to the other module, like 6608? Thanks
Re: CMM image
Hi CF,
You are most correct :) You will use session command (session slot x processor 0) where x is your module number.
Hope this helps!
Rob
142
