Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Cobras 7.0.83 12-22-2009 Access errors
Using latest down load of cobras  from 12-22-2009 7.0.83
I am trying to run cobras against a  Unity 5.01 UM server for export for an upgrade to Uconn 7.13. We are using a USB  drive attached to the Unity server for MDB storage.
I have run Permissions wizard check  and DBwalker and all looks good. Also Checked Exchange rights and  UnityMsgStoreSvc had correct rights
Logged into unity as   ‘UnityMsgStorSvc”
I get these  errors on Export.
1/15/2010 6:37:24 PM: (error)  -2147467259 (Method '~' of object '~' failed) in
procedure ExportSubscriberMessages  of Module modMessages
1/15/2010 6:37:26 PM:              Message sent at: 12/18/2009 9:04:57 AM,
Subject=Message from an unidentified  caller (Anonymous)
1/15/2010 6:37:26  PM:                  1 wav stream(s) found for message - appended
to  export
1/15/2010 7:00:23 PM: (error) 70  (Permission denied) in procedure
1/15/2010 7:00:24 PM: (error) could  not delete temporary message file - another
process may have it  locked:c:\COBRAS_temp_Message.wav
1/15/2010 7:00:24  PM:                  1 wav stream(s) found for message - appended
to  export
1/15/2010 7:00:24 PM: (error) 75  (Path/File access error) in procedure PackWAVFile
of Form  frmMain
On the import on  XP with USB drive attached (tried to import 183 users that were (Cicco Switch  users) Have 388 that are NEC switch users) Needed to do two imports for User  template.
(since was UM  Customer asked that we try import anyhow as we were running low on  time)
SubscriberObjectID=a6ea15af-03c0-4fe2-9df8-0acb76bb5129
1/16/2010 1:16:28 AM: (error)  -2147467259 (Unrecognized database format
'E:\COBRAS\Export\Backups\COBRAS_Backup_100115_18_32_25\UnityDBData_Backup_100115_18
_32_25.MDB'.) in procedure  FirstPassSubscriberCreation_CUC of Module
modImportCUCObjects
1/16/2010 1:16:28 AM: (error) 3704  (Operation is not allowed when the object is
closed.) in procedure  FirstPassSubscriberCreation_CUC of Module  modImportCUCObjects
1/16/2010 1:16:28 AM: (error) could  not find primary call handler in MDB file using
ObjectID='{7891E967-5CD0-4584-A552-2D1C49F4A17E}in  FirstPassSuscriberCreation_CUC
The Import started and then just  quit (Not in task or proccesses list anymore) the application after about 5 to  10 minutes.
We rebooted and started again and  the cobras cam up and when we tried to open the MDB it said it was read only and  need to be R/W. When itot file manager and it was not Read only was  R/W
I tried to open with Access and it  said it needed repaired so tried to repair it (Should have made original copy of  MDB before Starting).
Tried to start cobras again and got  the Read only error. Scrubed and whent back to Unity 5.01
Any Ideas why this would have Done this and What I can do to try to get this to run properly ?
598
