COBRAS unity connection import - SDK install issue
Hello All,
I am trying to get the cobras import tool to install.  It requested that I install the IBM Informix client SDK on my machine.  I downloaded the install files and ran it
I get an error saying I am installing 32bit on a 64 bit and to add the a path prefix.
I looked on the help at
www.ciscounitytools.com
and they say to add the following command from the command line where the program is installing from
set PATH=C:\WINDOWS\SysWOW64\;%PATH%
then run the install from the command line
I have tried it multiple times but get that same error saying i need to add that path
anyone run into this before?
thanks
1 REPLY
I got it to work by doing this
Right click on my computer and properties; on the left side bar click on advanced
system settings and then advanced tab click on Environment Variables button scroll
down in system variables and go to path, select that and click edit at the very start
type the following:
C:\Windows\SysWOW64
429
