Bronze
COBRAS
Hello Folks,
I am trying to Activate and Strat the "Connection Database Proxy" in order to use COBRAS but the service doesn't start. It stays in the "Service in transition" mode for while and stops right after. I am using the "cmadmin" username and password but it looks like this is not the problem.
MK
Hall of Fame Super Red
Re: COBRAS
Hi MK,
Hope all is well buddy
Can you try setting this as a "first" step;
To Change the Database Proxy Service Shutdown Timer
Step 1 In Cisco Unity Connection Administration, click System Settings > Advanced > Connection Administration.
Step 2 In the Database Proxy: Service Shutdown Timer  field, enter a value between 1 and 999 days.
A value of zero disables the Database Proxy Service.
Step 3 Click Save.
Cheers!
Huff
Bronze
Re: COBRAS
Thanks Rob, it's working now. Do I need to start this service in the Sub as well? Do I need to put the time back to 0 when I am done with the backup? Do I need to shutdown the Sub while importing the data to the Pub?
MK
Re: COBRAS
Hi MK<
Good stuff
1. only needs to be started on Pub
2.the Database Proxy service will shut down automagically after the days specified
3. you shouldn't need to shut down the Sub
Cheers!
Rob
Bronze
Re: COBRAS
Thanks man,
MK
Bronze
Re: COBRAS
Hello Rob,
Could you please send me your email address to runbigtime@yahoo.com. I need to share a document with you and need your opinion.
MK
447
