Codec mismatch outgoing calls CUCM
In CUCM 7.0 i configured one Device Pool with  one  Region codec IntraRegion G729 and InterRegion 729.
I configured that device pool in sip trunk and IP phones. Also in SIP trunk i choose MTP required and MTP prefered originated codec G729/G729a.
I have configured IOS MTP and Xcode  in Cube and i can receive incoming calls and i see in cube that MTP is used.
But  when i try to make outbond calls i see in cube the following error VOICE_IEC-3-GW: SIP: Internal Error (180, codec mismatch): IEC=1.1.278.7.104.0 on callID 2953 GUID=CC56E7AF147 ) and call fails.
I think CUCM triyng to use G729 instead of G729a. is possible to force that in CUBE ou CUCM?
Any ideas why outgoing call could be failling?
In outgoing calls which region setting force codec is intracodec or intercodec of device pool of ip phones?
In cube i have applied to dial-peers:
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711alaw
codec preference 4 g711ulaw
And also configured:
dspfarm profile 1 mtp
  codec pass-through
codec g729ar8
codec g729r8
maximum sessions software 100
associate application SCCP
dspfarm profile 4 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729br8
codec g729r8
maximum sessions 21
Best Regards
MC
  • IP Telephony
make sure you have an inbound dial-peer for calls coming from CUCM to the CUBE to enforce or negotiate the codec using the codec class
lets say your CUCM extensions number are in the range of 100 to 199
create a voip dialpeer just for enforcing the codecx
dial-peer voice 80 voip
session protocol sipv2
answer-address 1..
voice-class codec 1
also you can try to uncheck MTP required as well
hope this help
if helpful rate
Outgoing calls is matching  incoming dial-peer (2) in cube that is thte dialpeer to CUCM when i receive an incoming call. Provider is sending Full  Number as DDI. should i create a new dial-peer as you suggestted or i can put answer-adress in this dial-peer 2 voip? Also answer address for extension number or full External number?
dial-peer voice 1 voip
description Outgoing to Provider
translation-profile outgoing remove_zero
destination-pattern 0T
voice-class codec 1
session target ipv4:X.X.X.X (ip address provider)
session transport udp
dtmf-relay rtp-nte
ip qos dscp af41 signaling
no vad
dial-peer voice 2 voip
destination-pattern 2........
voice-class codec 1
session target ipv4: X.X.X.X  (Callmanager ip address)
session transport tcp
dtmf-relay rtp-nte
no vad
Best Regards
you can make the dial-peer as incoming voip dial-peer for CUCM calls to CUBE
the answer-address has to match the calling number of the phones as they reach the gateway
if they reach the gateway as 2........ then put like this
if they reach the gateway as the full e164 format then put the patterns like this
you confirm by debugging voip dial-peers and see how the number looks like when it reach the gateway from CUCM
hope this help
1166
