Codec Problems
blackswans
Can 7911's start the call with G729 directly without a transcoder or does it need a transcoder for starting g729 calls?
Jaime Valencia
Whenever 2 endpoints support natively G729 there is no need to use an XCODER for the call
Cisco Unified IP Phone 7911G
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps6565/product_data_sheet0900aecd8039de52.html
java
if this helps, please rate
java
ok then another question comes;
ServiceProviderGW----HQ----GW====GW---Branch
Can I make the branch ip phones talk G729 from the link which goes to the HQ, and then when they reach there turn them to g711 and then goes to the Service ProviderGW with g711... Is it possible ?
thanks
configure the GWs i point in different regions and have them talk G711 to do that
java
java
sorry but what do you mean by i point ?
