codecs problem
hello,
i have two call manager over a intercluster-trunk between us.
IN fact, when i used the G711u codec between ccm every thing is OK. But i need to setup calls over G729 codec between ccms, So when i used G729 i cant setup call easily, and the voice quality is little bad.
So i need help
thank u in advance
1 REPLY
Silver
Re: codecs problem
The issue may be due to one site configured for g.729 and the other g711, try congiguring the same parameter in both the site.also you need to apply QOS
93
