01-06-2009 08:20 AM - edited 03-15-2019 03:20 PM
I`ve just downloaded the two IOS files I require for an upgrade and have combined them using the COPY UCSInstall.....PART1OF2+ UCS....PART2OF2 UCSInstall....SGN.ISO as per Cisco but the resultant file is very much smaller - is this correct,Am I missing something?
Solved! Go to Solution.
01-06-2009 09:09 PM
you forgot the /B option (which means binary mode).
COPY /B File1+File2 Dstfile
01-06-2009 08:50 AM
If I recall the file should be the size of the 2 separate files combined, it's around 2.5 Gb.
HTH,
Chris
01-06-2009 09:09 PM
01-07-2009 02:25 AM
Thanks for that - it was the /B statement but the resultant file was as a .sgn extension not sgn.iso - is this correct?
01-07-2009 09:46 AM
you could rename it to .sgn.iso. Not sure if CUCM is picky on file extensions.
