02-03-2009 03:23 AM - edited 03-15-2019 03:56 PM
Where I can found the command reference guide for IP Phone 7941g in order to remotely modify the configuration of a Cisco IP Phone 7941g?
Thank you.
Best regards.
Massimiliano.
Solved! Go to Solution.
02-03-2009 03:36 AM
You cannot modify the configuration of a phone via SSH. The access and commands are not documented.
Configuration and settinga are made exclusively with the .xml files that the phones loads via TFTP at boot.
02-03-2009 03:36 AM
02-03-2009 05:05 AM
Thank you.
Best regards.
Massimiliano.
02-03-2009 05:06 AM
You are welcome.
Thanks for the nice rating and good luck!
