Community Member
Common Phone Profile in CUCM 6.0
Under the Common Phone Profile configuration, there is something called "Local Phone Unlock Password".
What for is this?? can someone through some light on this...
I could not understand in which scenario this can be used...
1 REPLY
Hall of Fame Super Red
Re: Common Phone Profile in CUCM 6.0
Hi RV,
On the IP Phone when you press the settings button and press **#, you will then find that you can edit tftp, ip, subnetmask, router etc. with the edit softkey.
When you set the "Local Phone Unlock Password" on the Common Phone Profile this becomes password protected. So when a user presses settings and **# they are asked for this password before anything can be edited via the phone.
Hope this helps!
Rob
347
