Community Member
Communication Manager 6.0 - what application included?
What applicaiton included in CM6.0? I know Call manager and Mobility manager are included. what's meaning the Unity connection able to install in the same box? Is the software shipping with CM6.0 or order separately and intall in the same box?
Thanks in advance,
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Communication Manager 6.0 - what application included?
Hi John,
The version of 6.0.1 you are referring to is the "Business Edition" designed for Medium sized deployments. The Enterprise version is fairly different. Here are some related docs for both;
Cisco Unified Communications Manager Business Edition is an easy-to-manage solution that combines voice, video, mobility, and messaging on a single server to simplify system administration and reduce hardware and operating expenses. This solution provides cost-effective deployment options for medium-sized organizations with smaller IT staffs that require all the advanced capabilities of Cisco Unified Communications Manager (formerly Cisco Unified CallManager), Cisco Unity? Connection, Cisco Unified Mobility (formerly Cisco Unified MobilityManager), and integrated management on a single server to expedite migration to unified communications.
The solution includes many new capabilities designed specifically for medium-sized organizations.
From this doc;
http://www.cisco.com/en/US/products/ps7273/products_data_sheet0900aecd805e6985.htmlhttp://www.cisco.com/en/US/products/ps7273/products_data_sheet0900aecd805e6985.html
Cisco Unified Communications Manager Business Edition Documentation Guide for Release 6.0(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/docguide/6_0_1/dg601cr.html#wp1034252
Cisco Unified Communications Manager 6.0 is an enterprise IP telephony call-processing solution that is scalable, distributable, and highly available. Multiple Cisco Unified Communications Manager servers are clustered and managed as a single entity on an IP network, a distinctive capability in the industry that yields scalability of 1 to 30,000 IP phones per cluster, load balancing, and call-processing service redundancy. Cisco Unified Communications Manager 6.0 builds upon the feature set available today with Cisco Unified Communications Manager 5.1(1) and Cisco Unified CallManager 4.2(3).
From this doc;
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/products_data_sheet0900aecd805e323f.html
Cisco Unified Communications Manager Documentation Guide for Release 6.0(1)
http://www.cisco.com/en/US/customer/docs/voice_ip_comm/cucm/docguide/6_0_1/dg601.html
Hope this helps!
Rob
EDIT: Chris, you have again highlighted my poor typing skills :) Congrats on the RED Star (Looks good on you!) Rob
Hall of Fame Super Silver
You can have CM and UC running on the same server, the solution is called "Cisco Unified Communications Manager Business Edition"
http://www.cisco.com/en/US/products/ps7273/index.html
It can be ordered using a single top-level bundle part number. The top-level part number allows you to configure the entire system, including hardware, software, and user licenses.
HTH, please rate all useful posts!
Chris
Hi John,
From this doc;
From this doc;
Hope this helps!
Rob
Community Member
Hey Gents -
One other related question to this:
Our company Internal IT Operations is looking to move to CallManager 6.0 and was wondering if it would be compatible with our MeetingPlace 5.3. I saw on the Compatibility Matrix that MeetingPlace 5.3 is compatible with CallManager 5.x, but has anyone heard any updates on CCM 6.0 compatibility?
109
