Comparing CUCM 6.x versus CUCM 7.x
anacletodeleon
I am looking for a document comparing two major versions and a guidelines (pros and cons) as to why a customer who has 4.x would upgrade to 7 instead of 6 or vice versa
thanks
Jaime Valencia
That doc doesn't exist, you can look the RNs for each version to see what new features have been included in each
If you search CCO with just the product name you run across docs like this one:
Cisco Unified Communications Manager 7.0
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps556/solution_overview_c22-493511.html
Which contains:
Table 1. New Features in Cisco Unified Communications Manager 7.0
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Rob Huffman
Hi Anacleto,
Maybe this doc that I did up not too long ago may help (attached)
Cheers!
Rob
EDIT: The new site won't allow this content for some reason, If you
want the doc just email me @
rhuffman@mtroyal.ca
Thanks Rob.  I sent you emails about the doc so if you can kindly reply to it
regards
Hi Jhun,
It's on the way my friend
Cheers!
Rob
