Compatibility between Catalyst 6606 MGCP and CUCM 8.6
cristian.munoz
Level 4
Level 4
Hi Guys
I have a question. Are the Catalyst 6606 MGCP and CUCM 8.6 compatible?
TIA
Cristian Munoz.
Rob Huffman
Hi Christian,
I'm not sure if you meant 6606 or perhaps the 6608 blade?
If it's the 6608 then yes, it's still supported
Default Loads for Cisco Unified Communications Manager Release 8.x (Table 31)
Equipment Description
8.6(2a)
8.6(2)
8.6(1a)
8.5(1)
8.0(3a)
8.0(2c)
Digital Access WS-X6608
cmterm-6608-4.0.0.32-mgcp.copsgn
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp302755
Cheers!
Rob
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
Dear Rob
Thanks for you answer.. I have the same information, but I can´t find interoperability using WS-X6600-6E1 Blade.
Regards..
Cristian.
Here is a doc for CUCM 8.6.1
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmsys/a08gw.html
Look at table 38-3
Cisco Communication Media Module (WS-X6600-6E1)
H.323
E1 PRI
So looks like it is supported but as H323
Still a valid reliable protocol.
Alex
Regards, Alex. Please rate useful posts.
My suggestion would be to get the blades replaced with ISR G2 gateways as even though they may still be supported in CUCM, the blades themselves have been EOS/EOL for some time.
Chris
