Community Member
Compatibility betweenCallnanager releases and Voice gateway
Is there a document which describe the compatibility between the callmanager release with the voice gateway using MGCP OR H323. There s the compatibility matrix but it doesn t give all the information....
I want to know if my CCM 3.3(4) can drive a Mgcp gateway (2851 with 12.4) or i can use H323?
1 ACCEPTED SOLUTION
VIP Purple
Re: Compatibility betweenCallnanager releases and Voice gateway
Take a look at tables 3 and 4 of the following document.
http://www.cisco.com/application/pdf/en/us/guest/products/ps259/c1650/cdccont_0900aecd8057f2e0.pdf
Hope this helps. If so, please rate the post.
Brandon
1 REPLY
VIP Purple
Brandon
127
