Community Member
Compatibility IP Phone Cisco x Nokia E61
Hi Guys,
My Customer need configure Nokia E61, but, the version CallManager 5.1.3 don't have this model. I see that IP Phone 7960 can be compatible,but, not is clear, it's right? or there another model?
Wilson
2 ACCEPTED SOLUTIONS
VIP Super Bronze
Re: Compatibility IP Phone Cisco x Nokia E61
I believe you need to order licensing and the COP file for installation into UCM from Nokia for this.
Hall of Fame Super Red
Hi Wilson,
Jonathan is most correct here (+5 points Jonathan :)
The support docs and software can be found here;
http://www.businesssoftware.nokia.com/nokia_intellisync_call_connect_for_cisco_downloads.php
Hope this helps!
Rob
VIP Super Bronze
Hi Wilson,
Hope this helps!
Rob
128
