compatibility of ip phone
Hi,  I have a customer who is using snom ip phones.  The are considering the cucm-be, however wishes to retain the snom phones.  The snom website mentions compatibility with cucm-5 but not any current versions.  Can someone throw in some light?
http://www.snom.com/en/products/snom-efficient-line/snom-300/
http://wiki.snom.com/Interoperability/PBX/CiscoCallManager
Everyone's tags (2)
Hall of Fame Super Silver
You can attempt to register
You can attempt to register them as 3rd party SIP phones, I know others have. Cisco used to publish supported 3rd party SIP phones here, but this link no longer works:
http://www.tekvizionlabs.com/3rdpartyprograms/sip_verification/verified_products.php
Chris
Thanks for the reply!  Much
Thanks for the reply!  Much appreciated.
Does this require additional licensing on the CUCM or we can use the CUWL or user licensing?
Nitin
Hi Nitin.This doc explains
Hi Nitin.
This doc explains what kind of license do you need to add Basic or Advanced third party SIP phone on CUCM
http://www.cisco.com/c/dam/en/us/products/collateral/unified-communications/unified-communications-licensing/cisco_unified_communications_licensing_qa.pdf
Basically if you own enough UCL or UWL you'll be able to add SIP third party phones
Carlo
Please rate all helpful posts "The more you help the more you learn"
Depending on configuration
Depending on configuration either CUWL or UCL will work.
Chris
54
