Community Member
Concurrent/Simultaneous Voiec Calls
We are planning for IP Telephony solution.  We need at least 64 Simultaneous calls in system.   Call manager ca support up to 1000 users.
We are option for Cisco Business Edition 6000 series.
SO, How many Concurrent/Simultaneous Voice calls can handle by this device.
Thanks in advance.
Sandeep
1 REPLY
Hall of Fame Super Silver
Sandeep,
There is no defined number as it depends on many other varaibles, calls themsevels do not put a lot of stress on CUCM as all it is doing is bridging signaling streams, no actual voice packets go through it. You can use the capacity tool (if you have access) to estimate the load on your server:
http://tools.cisco.com/cucst/faces/
HTH,
Chris
180
