Conecct E1 R2 to a router 2851
altesan35
Hi, I want connect a E1 to a router 2851 with CUCME 4.1, but whenever I dial some DID (after configure the card VWIC2-2MFT-T1/E1), the calls are not routed to the extensions, the first thing the router do is give me a tone of reorder to dial the extension and then the call is routed to the extension
conf t
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
Noete you can group the analog ports under trunk group, that will allow you to collapse most DPs under a single one.
14 Replies 14
dhccoid.com
Do you have more than one Pots dial-peers configured?
If so ensure you have incoming called-number. & direct-inward-dial on the dial-peer you expect inbound calls to use.
hi, thanks for your answer...
yes, I have more dial-peer's pots, I erase thats but the problem continue.
I attach the actual configuration, thanks
conf t
direct-inward-dial
ok, i will try this, and after I tell you the result, thanks
Hi, me again.
the problem to receive calls, was solved (thank's for yours councils), but I have a new problem.
Now, I can not make calls to PSTN from PBX. PBX are a Panasonic 1232 with E1 card
Need to see configuration. Do not send full configuration, only voice related, do not use attachments if possible.
Please remember to rate useful posts with the scrollbox below.
This the configuration
controller E1 0/2/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
country telmex
category 2
answer-signal group-b 1
caller-digits 4
dnis-digits min 4 max 4
ani-digits min 0 max 20
dnis-complete
description TRONCALES DIGITALES AXTEL
controller E1 0/2/1
framing NO-CRC4
clock source internal
ds0-group 0 timeslots 1-15,17-20 type r2-digital r2-compelled ani
cas-custom 0
country telmex use-defaults
category 2
timer interdigit incoming 2500
dtmf timer inter-digit 2500
description TRONCALES PANASONIC
voice-port 0/2/0:0
cptone MX
voice-port 0/2/1:0
cptone MX
timeouts interdigit 3
timing digit 400
incoming called-number 55508916..
direct-inward-dial
port 0/2/0:0
dial-peer voice 2 pots
description PBX
destination-pattern 16..
direct-inward-dial
port 0/2/1:0
forward-digits all
dial-peer voice 3 pots
corlist outgoing ll-loc
description LLAMADAS LOCAL
destination-pattern 9........
direct-inward-dial
telephony-service
service dnis overlay
user-locale ES
network-locale ES
time-zone 9
time-format 24
date-format yy-mm-dd
dialplan-pattern 1 55508916.. extension-length 4 extension-pattern 14..
max-conferences 2 gain -6
moh twenty.au
transfer-system full-consult
thanks
Is the E1 to PBX up ? Check show controllers E1.
Is the PBX ready to receive 4 digits beginning with 16 ?
If yes to both questions, take "debug vpm signal" with "term mon" whe dialing 16xx.
Sorry, I think not explain me good
When I try make a call to outside, the router give me dial tone, however if I dial any digit sequence, router only catch first digit and ignore the rest of digits
Explain which calls work, and which ones do not. Check controllers also.
One more time, s
orry, my english is not very well
I try connect the PBX (Panasonic 1232) to a router Cisco 2851 (with CCME 4.1) using card VWIC2-2MFT-T1/E1.
Incoming calls (Router to PBX) are completed succesful, but outgoing calls (PBX to Router) are not completed.
When I try make a call (from PBX), I hear dial tone and saw with the "show voice call summary" command that one line is goes off hook, then I start press digit, only the first digit is understand, the other digits are showed incorrectly (example 4#, or #) so the call is not complete.
What does you mean with check controllers, I don't understand???
I attach the debug file
This is ended
I configure the route of the calls to the interface appropriate. Thanks for your help
Hello there. I have a similar issue. Could you post the commands you used to solve you issue ?
Please open new thread for a new problem, describe the problem in detail and include the relevant configuration.
