Conect PBX to Router 2800
I wonder if you could help me telling me if there is a way to connect a Nortel PBX supports only signaling type R1-itu T1/E1 card by connecting it with a Cisco 2800 router?
1 ACCEPTED SOLUTION
Green
Les,Same URLCisco 1750 and
Les,
Same URL
Cisco 1750 and Cisco 1751
ds0-group ds0-group-number timeslots timeslot-list [service service-type] type {e&m-fgb | e&m-fgd | e&m-immediate-start | fgd-eana | fgd-os | fxs-ground-start | fxs-loop-start | none | r1-itu | r1-modified | r1-turkey}
no ds0-group ds0-group-number
Cisco IOS Release 12.1 and Earlier Releases
ds0-group ds0-group-number timeslots timeslot-list [service service-type] type {e&m-fgb | e&m-fgd | e&m-immediate-start | fgd-eana | fgd-os | fxs-ground-start | fxs-loop-start | none | r1-itu | r1-modified | r1-turkey | sas-ground-start | sas-loop-start}
So looks like yes you can use a 1751 for r1-itu support
Also from the compatability matrix you can use a VWIC-2MFT-T1 in a 1751
http://www.cisco.com/c/en/us/support/docs/routers/2600-series-multiservice-platforms/5111-voice-comp-matrix.html#platform
Hope this helps
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
Green
Hi,See this link:=http://www
See this link:=
http://www.cisco.com/c/en/us/td/docs/ios/voice/command/reference/vr_book/vr_d2.html#wp1452165
Under ds0-group E1
Cisco 2691, Cisco 2600XM Series, Cisco 2800 Series (Except Cisco 2801), Cisco 3660, Cisco 3700 Series, Cisco 3800 Series
ds0-group ds0-group-number timeslots timeslot-list type {e&m-delay-dial | e&m-immediate-start | e&m-lmr | e&m-melcas-delay |
e&m-melcas-immed | e&m-melcas-wink | e&m-wink-start | ext-sig | fgd-eana | fxo-ground-start | fxo-loop-start | fxo-melcas |
fxs-ground-start | fxs-loop-start | fxs-melcas | r2-analog | r2-digital | r2-pulse}
Under ds0-group E1
ds0-group ds0-group-number timeslots timeslot-list type {e&m-delay-dial | e&m-fgd | e&m-immediate-start | e&m-lmr | e&m-wink-start |
ext-sig | fgd-eana | fgd-emf [mf] [ani-pani] [ani] | fxo-ground-start | fxo-loop-start | fxs-ground-start | fxs-loop-start}
R1-itu is NOT supported on the 2800 series
Hope this helps
Alex
Hi Alex,Would a Cisco 1751-V
Hi Alex,
Would a Cisco 1751-V do the trick? could we swap the VWIC-2MFT-T1 from the 2800 to a 1751? I'm unable to find configuration examples of MF R1 signaling types being used via the 1751.
Nortel PBX (MF R1 Signaling) connected to 1751? our final goal is have the other end of the VPN running VoIP. Its a little tricky...
Thank you for your help
Les
Green
Les,
Same URL
Hope this helps
Alex
165
