Conf Bridge CM 6.1
Trying to register a new Conf bridge with CM 6.1 and it shows Registration "Rejected". Here is the GW config. Ideas?
sccp local Loopback0
sccp ccm 10.224.13.12 identifier 2
sccp ccm 10.224.13.11 identifier 1
sccp
sccp ccm group 1
bind interface Loopback0
associate ccm 2 priority 1
associate ccm 1 priority 2
associate profile 10 register SIN-CONF
dspfarm profile 10 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
associate application SCCP
Re: Conf Bridge CM 6.1
I'm not sure about "SIN-CONF". You might try removing the "-". Also, make sure the bridge name in CUCM matches this exactly.
Hope this helps.
Brandon
I experienced the same issue. Did you configure it as IOS enhanced conference bridge or just IOS conference bridge, which does matter.
also perform a shut/no shut on your profile 10
Please remember to rate useful posts, by clicking on the stars below.
306
