Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Conf issue
hi
i have a problem with meet me conference like this:
a user initiates a meet me conference, and when a PSTN (landline) caller calls the meet me number he joins the conference without any problem, the issue is that when a caller calls the meet me no. from his mobile he gets a busy tone and cannot join the conference the same things happens when an internatioanl caller calls the meet me no. he encounters the same problem as well.
did any one happen to have the same issue or solved it?
please advise
thanks
1 REPLY
Re: Conf issue
if you're using the SW CFB for this verify the call legs for the mobile and international calls are made using G711, if they're using G729 they won't connect because the SW CFB only supports G711
java
if this helps, please rate
www.cisco.com/go/pdi
104
